Results 1 to 6 of 6
    rwong48's Avatar
    Posts
    ROM
    euroskank cm10 kangs
    Default Replacement battery cover?
    I'm looking for a Sprint back cover and I can only find Verizon/GSM ones on eBay.
    I remember reading that the Verizon one is non-compatible. I'll verify with my friends this weekend.
    Where can I get a Sprint one? Or should I attempt to mod one of the other ones?
  2. #2
    VW Maverick's Avatar
    Master of Time and Space
    Posts
    ROM
    JBSourcery V5.2 w/4.2.2
    Default Re: Replacement battery cover?
    The first question is Why?
    Are you getting an extended battery or something?
    Mav.
    Scissors cuts paper, paper covers rock, rock crushes lizard, lizard poisons Spock, Spock smashes scissors, scissors decapitates lizard, lizard eats paper, paper disproves Spock, Spock vaporizes rock, and as it always has, rock crushes scissors.
    rwong48's Avatar
    Posts
    ROM
    I wanted to have a back cover with touchstone mods and one without the extra bulk.
  4. #4
    stinkyfischer's Avatar
    Posts
    Global Posts
    108 Global Posts
    ROM
    AOKP
    I love the touchstone mod!! I put the coil inside a case though not inside the bakcover and it works great from day one.
  5. #5
    Default
    Sent from my Galaxy Nexus usinsg Tapatalk 2
  6. #6
    Default
    Try the banker 2200mah next. Battery with the seidio surface or active extended cases the sprint battery cover will stick out a little but the extended cover will protect it for extra protection get add on kit with silicone cover and exoskeleton
