Results 1 to 15 of 15
Like Tree3Likes
  • 1 Post By garymdietz
  • 2 Post By jean15paul
    Default Sprint Galaxy Nexus: Help! Bluetooth won't turn on
    I'm running a stock GNex and when I try to turn on my bluetooth it just stays on the screen saying bluetooth turning on. Any suggestions?
  2. #2
    jj14x's Avatar
    Posts
    Global Posts
    549 Global Posts
    ROM
    Stock
    Default Re: Help! Bluetooth won't turn on
    Try restarting the phone?
    Default
    A battery pull worked. Thanks
  4. #4
    jj14x's Avatar
    Posts
    Global Posts
    549 Global Posts
    ROM
    Stock
    good to know Thanks for the update
    Default
    No problem.
  6. #6
    mikestorm's Avatar
    Posts
    Global Posts
    1,002 Global Posts
    ROM
    Cyanogrnmod 10.2
    This apparently is a known issue (my phone is affected as well). Something happens when Airplane mode is turned on and off. Despite Airplane mode being off, Bluetooth functionality is borked and doesn't right itself until you reboot. Once you reboot, BT functionality works until you toggle airplane mode again.
  7. #7
    Maybe I am crazy, but multiple reboots on a stock GN 4.1.1 did *not* fix the problem for me. I needed to take the battery out for over a minute and then restart. It seems to be back working now.
    And for me, it was not just the BT that failed with the settings widget grayed out and in the "always trying to turn on mode" but also WiFi.
  8. #8
    Quote Originally Posted by garymdietz View Post
    Hi, im having the same issues. restarting does not solve the issue for me. Can some provide steps? Do i just take out the battery and or turn the phone off first before taking the battery out.
    Any help would be appreciated!!
  9. #9
    For me, all I did was this:
    1. Turn off phone.
    2. Remove battery.
    3. Get a coffee. Finish coffee.
    4. Re-insert battery and cover.
    5. Turn on phone.
    6. Turn on BT and WIFI.
    7. Wash my coffee cup.
    Thanked by:
    jeremiahmegel likes this.
  10. #10
    1. Turn off phone.
    2. Remove battery.
    5. Turn on phone.
    Oh! ... That's my problem. I didn't wash my coffee cup. Thanks for clearing that up.
  11. #11
    IcerC's Avatar
    Posts
    Global Posts
    1,724 Global Posts
    So none of that worked for me so I flashed cyanogenmod and its fixed.
  12. #12
    It didn't work, but I suppose its because I ate a sandwich.
    EDIT: Those who don't like coffee can try this: .
  13. #13
    I had the same problem after rooting my nexus s.
    The battery-pull-solution worked fine!
    Thank a lot
  14. #14
    I've been having the problem with my bluetooth not turning on no matter what I do. I've even downloaded the bluetooth enhancer from the Play Store. I really need some assistance! & this didn't happen till after the Samsung update recently! I have a Samsung Galaxy S3.
  15. #15
    Quote Originally Posted by misslocs View Post
    Hi misslocs, And welcome to AC.
    You're having problems on your Galaxy S 3? This is the Galaxy Nexus forum. Problems like these are usually specific to the phone model, so you really need to ask your questions in the Galaxy S 3 forum.
    Good luck with your bluetooth.
B
