Results 1 to 6 of 6
- 08-29-2012, 08:44 PM
Thread Author #1
- 08-29-2012, 09:19 PM #2
Re: Nexus speaker volume
im running cyanogenmod "*****" and it has solved the issue with the low speaker volume.
- 08-31-2012, 11:11 AM #3
- 08-31-2012, 02:20 PM #4
- 08-31-2012, 03:22 PM #5
Volume+ does work, but to me it sounds distorted. So if you dont want to root and rom, that may be your best bet.
- 09-01-2012, 11:12 PM #6
I tried the free version for the Galaxy Nexus and it did not work, so I started reading on different forums and found that the paid version is the only one that works for the Nexus. for I have it set to 12 and it is just right for how loud it gets. If I set it to 13 or higher the speaker just rattles and the sound is really distorted.
Reply
