Page 1 of 2 12 LastLast
Results 1 to 25 of 45
Like Tree1Likes
    harold42483's Avatar
    Posts
    Global Posts
    639 Global Posts
    ROM
    Motorola Xoom Running ICS
    Default Battery life worse after JellyBean?
    So I notice that my battery life has been a lot worse. I think it has to do with signal as I feel the signal strength is weaker. Here are my battery stats.
    One thing I have noticed voice calls is extremely high at 23% and only 24m talk time. Battery life worse after JellyBean?-uploadfromtaptalk1347489181771.jpg
    Anyone having this issue PR have any suggestions? By the way I have the Samsung extended battery 2100mah
  2. #2
    VW Maverick's Avatar
    Master of Time and Space
    Posts
    ROM
    JBSourcery V5.3 w/4.2.2
    Default Re: Battery life worse after JellyBean?
    Odd. I have found mine to be about the same, if not slightly better.
    Mav.
    Sent from my Galaxy Nexus w/Jelly Bean.
    Scissors cuts paper, paper covers rock, rock crushes lizard, lizard poisons Spock, Spock smashes scissors, scissors decapitates lizard, lizard eats paper, paper disproves Spock, Spock vaporizes rock, and as it always has, rock crushes scissors.
    Posts
    Global Posts
    639 Global Posts
    ROM
    Quote Originally Posted by VW Maverick View Post
    Mav.
    Ya that's pretty good battery life. SK why mine is so bad
  4. #4
    Zeinzu's Avatar
    Posts
    Global Posts
    326 Global Posts
    Battery life bad on Jelly Bean?
    Posts
    Global Posts
    639 Global Posts
    ROM
    Can you click on the graph to see your network coverage. Also what battery and are you on WiFi all day?
  6. #6
    Battery life is terrible. I dropped 6% in less than 10 minutes. Wtf????
    Posts
    Global Posts
    639 Global Posts
    ROM
    Quote Originally Posted by moonoverparma00 View Post
    Please post battery statistics. Settings > battery. Thanks
  8. #8
    .The Word Alive.'s Avatar
    Posts
    ROM
    Stock
    Battery life is not worse for me. Battery life worse after JellyBean?-uploadfromtaptalk1347508792461.jpgBattery life worse after JellyBean?-uploadfromtaptalk1347508811356.jpg
  9. #9
    I'd say remove all your downloaded apps and slowly reinstall. Most likely ya got an app misbehaving. I usually factory reset and start over between android versions. I odined to jelly bean battery life has been good
  10. #10
    Zeinzu's Avatar
    Posts
    Global Posts
    326 Global Posts
    Quote Originally Posted by harold42483 View Post
    No I was not on WiFi all day. I forget WiFi on when I go to work, and we don't have WiFi there. I get good coverage and signal. 2100mah OEM Samsung battery.
    Sent from my AOSP Android 4.1.1 Galaxy Nexus.
  11. #11
    I disabled Google wallet and battery hasggotten better. I did this on my nexus s and it also helped.
  12. #12
    Google now I hear is a killer too.
  13. #13
    Zeinzu's Avatar
    Posts
    Global Posts
    326 Global Posts
    I wonder why I don't have to disable anything to get good battery life...
  14. #14
    Quote Originally Posted by Zeinzu View Post
    Me too? O_o
  15. #15
    i'm on a rooted unlocked vzw gnex...aokp jb1 leankernel, but i think i have some good advice.
    watchdog helps monitor for misbehaving apps, and in my experience doesnt drain much extra at all (according to gsam battery monitor, .4% of ~30% so LOW).
    checking graphs can help you see if you are getting bad cell service.
    google now does increase drain depending on your settings. many of its services have to constantly ping your location among other things.
    some general knowledge: your phone doesnt actually charge up to 100%, and so you may see it fall fast immediately after charging to what it reports as 100%. this is to protect it's long term life. also, charge it often trying to keep the percentage between ~40 to ~95. for those who saw their level drop fast was it after charging? after an account sync? in bad service area?
  16. #16
    I too have noticed significantly reduced battery life and increased charge time since my Samsung Galaxy Nexus was updated to JB. As a note, I just reset my phone back to stock and then rooted it. Still on the stock ROM, though.
    Battery life worse after JellyBean?-screenshot1.jpgBattery life worse after JellyBean?-screenshot2.jpgBattery life worse after JellyBean?-screenshot3.jpg
    I'm about as evil as beating a unicorn to death with a bag of rainbows.
  17. #17
    mine is the same. just rooted and on stock. battery lasts about 3-4 hrs with light use. when i use it heavy it lasts for like 30 min. im on the samsung 2100mah battery. great area for reception.
  18. #18
  19. #19
    I did the Google wallet thing and it works a little.
  20. #20
    No luck. Still 6 hrs on extended battery.
  21. Thread Author  Thread Author    #21
    Posts
    Global Posts
    639 Global Posts
    ROM
    Well after a few weeks I noticed the battery life improved . I will send stats later today
  22. #22
    I've noticed mine getting progressively worse. I'm having to charge it 4 to 5 times a day. I've got CyanogenMod 10 ROM on board and use the profiles to switch between usage settings when at work, home and driving. I'm managing the phone as best I can, but it doesn't seem to be making a difference. I'm reading in several other forums that over time, users of the Galaxy Nexus are finding the battery to be terrible. I'm beginning to think I'm just going to have to live with it...
  23. #23
    So I decided to implement Gekko's suggestions, basically micromanaging the phone and completely negate the dynamic multimedia experience of the smartphone. Even implementing his suggestions, I only got ~8 hours of battery life. Very annoying.
    Battery life worse after JellyBean?-battery_usage_ss1.jpgBattery life worse after JellyBean?-battery_usage_ss2.jpgBattery life worse after JellyBean?-battery_usage_ss3.jpg
  24. #24
    Quote Originally Posted by deutschdragon View Post
    1. huh? how exactly are you "completely negating the dynamic multimedia experience of the smartphone"? what are you not able to do as i result of these settings?
    2. so you went from 3 hours of battery life to 8 hours with the new settings?
  25. #25
    get rid of Panel App (isnt that the equivalent of a spammy browser tool bar?) and thats about 2 more hours of battery life
    whats your screen brightness set at?
  1. Who's battery life sucks after 5.5.893 OTA?
    By jpvybes in forum Droid Bionic
    Last Post: 01-05-2012, 09:23 PM
  2. Battery life poor after update.
    By fivegear in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 12-29-2011, 06:32 PM
  3. Battery life terrible after PBJ Kernal/Root
    By koala-czyk in forum Software Development and Hacking
    Last Post: 08-03-2011, 08:32 AM
  4. Battery life worse after 3.1
    By SlickMoney in forum ASUS EeePad Transformer
    Last Post: 06-05-2011, 06:54 PM
  5. Anyone else's battery life WORSE with 2.2?
    By benjamin_ in forum Verizon Droid Incredible
    Last Post: 09-04-2010, 11:35 PM
