Results 1 to 8 of 8
    VW Maverick's Avatar
    Posts
    Carrier
    Nitrogen OS 7.1.1 Nougat
    Cool App to activate the notification light when charging battery?
    Is there an app that works on our phones that turns on or flashes the notification light during battery charging?
    Thanks.
    Mav.
  2. #2
    Default Re: App to activate the notification light when charging battery?
    I would have to reinstall and verify, but I believe "lightflow" had that option. (disclaimer, I had the pro version in ICS, did not reinstall it after the JB update.
    Posts
    Carrier
    I will check it out. Thanks.
    Mav.
    Sent on my Galaxy Nexus using the Continuum Transfunctioner.
  4. #4
    .The Word Alive.'s Avatar
    Posts
    Carrier
    Stock
    Yes light flow works for that.
  5. #5
    Battery LED Indicator is the one I currently have installed.
    Posts
    Carrier
    All good options.
    I found "Nexus Battery LED" that is workin for me.
    Thanks to all.
    Mav.
  7. #7
    I have Light Flow Lite. You can set the percentage and a color/notification for each state so I have low battery set to blink red at 10% (extended battery), steady red when charging, and it set to change to steady green when it reaches 90%.
    Sent from my Sprint Galaxy Nexus
  8. #8
    Have been using Bright Charge recently and it does what I want without me having to change any settings.
  1. Replies: 6
    Last Post: 08-07-2010, 09:21 PM
  2. Where is a setting to disabled the notification light?
    By greydarrah in forum Motorola Droid X
    Last Post: 08-04-2010, 08:52 AM
  3. Replies: 22
    Last Post: 05-20-2010, 01:33 PM
  4. Replies: 0
    Last Post: 01-28-2010, 10:15 AM
  5. Is there anyway to make the notification sounds last longer?
    By Theodore55 in forum Motorola Droid
    Last Post: 12-04-2009, 11:04 AM
