how to upload photos from pc to my galaxy nexus
Printable View
you can do one of a few things.
i recommend using an app called dropbox. It goes on your PC and your phone and you can keep the photos synced on both.
Otherwise, you can hook phone up to the computer and just drag and drop the photos back and forth
You can also use a free app called AirDroid that lets you wirelessly upload files to and from your PC and phone.
When you use the USB cord, you might also have to change the USB setting on the phone. If you don't seem to be seeing all your photos, or it isn't moving anything, you need to switch it. A notification pops up and you select the "other" option.
I can't get my hot spot to work at all really, wouldn't work on paranoid android and I'm running xylon ROM 4.2.1 now and still no hot spot anyone else having this problem or know of any possible fixes for it I'm not using an app to turn it on just going thru settings could that be the problem? Any and all input is of course greatly appreciated thks.
