Results 1 to 5 of 5
    Default help with phone
    how to upload photos from pc to my galaxy nexus
  2. #2
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    Carrier
    Something JB
    Default Re: help with phone
    you can do one of a few things.
    i recommend using an app called dropbox. It goes on your PC and your phone and you can keep the photos synced on both.
    Otherwise, you can hook phone up to the computer and just drag and drop the photos back and forth
  3. #3
    Danf's Avatar
    Posts
    Global Posts
    347 Global Posts
    You can also use a free app called AirDroid that lets you wirelessly upload files to and from your PC and phone.
  4. #4
    When you use the USB cord, you might also have to change the USB setting on the phone. If you don't seem to be seeing all your photos, or it isn't moving anything, you need to switch it. A notification pops up and you select the "other" option.
  5. #5
    I can't get my hot spot to work at all really, wouldn't work on paranoid android and I'm running xylon ROM 4.2.1 now and still no hot spot anyone else having this problem or know of any possible fixes for it I'm not using an app to turn it on just going thru settings could that be the problem? Any and all input is of course greatly appreciated thks.
  1. Help with phone update
    By innovationplus in forum Epic 4G Rooting, ROMs, and Hacks
    Last Post: 01-30-2012, 06:51 PM
  2. Help with phone
    By Sdude1200 in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 08-25-2011, 08:49 PM
  3. Need some Help with phone updates
    By SkyHeroMZ in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 08-18-2011, 01:31 AM
  4. I need some help with phone signal....
    By bamaatheart in forum General Help and How To
    Last Post: 03-06-2011, 08:12 AM
  5. Need some Help with phone updates
    By in forum Verizon HTC Thunderbolt
    Last Post: 12-31-1969, 07:00 PM
