1. jean15paul's Avatar
    I saw this posted on another forum, and thought I'd ask the smart folks here if this is safe and if it works.
    I've seen a lot of complaints about MMS on Sprint recently. This is supposed to fix it. Original post: [Cm10] Discussion Of Nightlies - Page 37 - Google Galaxy Nexus CDMA Experimental Mod - CyanogenMod Forum - Page 37
    Currently Running 12/14 nightly and I was having MMS issues with the stock messaging app as well. BUT I have fixed the issue. I'm not sure why this information isn't as widely availible, considering it was easy to do and works perfectly.
    Despite what android tells you when you download those third party apps to edit your APNs, it's actually quite easy to edit them yourself; using the voice dialer. Here's a little step by step guide that I whipped up from several sources so I can't really take any of the credit for this information:
    APN Settings for Sprint Galaxy Nexus running CM10
    Function: Fixes MMS send and receive error. Also fixes Auto-Retreive!
    Directions:
    • Go to Voice Dialer
    • Say "Open APNs" (Pronounce A-P-N)
    • Dialog will display open APNs, click it.
    Now, create TWO new APNs by hitting the settings button on the bottom right of the touchscreen. Enter the information in the fields exactly like so (Please note that you must even enter the asterisks seen here, although you can leave the fields labeled as <not set> alone):
    MMS Fix:
    • Name- Sprint
    • APN- cinet.spcs
    • Proxy- <not set>
    • Port- <not set>
    • Username- none
    • Password- ****
    • Server- *
    • MMSC- http://mms.sprintpcs.com
    • MMS Proxy- 68.28.31.7
    • MMS Port- 80
    • MCC- 310
    • MNC- 120
    • Authentication Type- <not set>
    • APN Type- mms
    • APN Protocol- IPv4
    Hit the settings button when you're done filling out the fields, and hit save.
    MMS over Wifi Fix:
    • Name- Sprint
    • APN- mms_over_wifi
    • Proxy- <not set>
    • Port- <not set>
    • Username- *
    • Password- *
    • Server- *
    • MMS Port- 80
    • MCC- 310
    • MNC- 120
    • APN Type- wifi
    Save and reboot. Then you're done! Send an MMS to yourself to verify.
    Someone telling me what to put in for a username and password make me a little nervous.
    01-23-2013 12:42 PM
  1. Is this a fix for Sprint MMS issues?
    By jean15paul in forum Sprint
    Last Post: 09-12-2013, 09:51 AM
  2. Is there a Fix for the Wifi issue without rooting my S3?
    By Jayhall2502 in forum Samsung Galaxy S3
    Last Post: 01-21-2013, 03:10 PM
  3. Is there a fix for this, or no?
    By MRW1215 in forum Verizon HTC Thunderbolt
    Last Post: 06-03-2011, 05:31 PM
  4. HTC is testing a fix for the screen grounding issue!
    By letsgoflyers81 in forum HTC EVO 4G
    Last Post: 06-24-2010, 12:02 AM
  5. A fix for the 30fps issue is (probably) on the way.
    By soldierblue in forum HTC EVO 4G
    Last Post: 06-15-2010, 09:36 AM
