Results 1 to 2 of 2
- 11-07-2012, 03:57 PM
Thread Author #1
I have a problem
I installed some apps, including My Story, from the Samsung store, and had to remove them when they completely hung up during the registration process. After uninstalling them, my phone seemed a little sluggish, and some apps glitchy or less responsive. I decided to do a factory reset. However now things have gotten a little worse. My screen brightness when on Auto constantly gets max bright and then dims, only to go max bright seconds later. Facebook app doesnt work properly ( worked flawlessly prior, there has been no update recently ) and some other lag issues, like when opening my email app, it sits with a black screen for a second or two before popping in... all in all Im worried that I have altered a system file somewhere on accident, and the factory reset doesnt seem to fix this as it only deletes user data.
My Question: Is there a way to truly reinstall android and completely factory reset it? I want a fresh install of the OS and everything. I am using a Sprint GN2 - 11-07-2012, 04:03 PM
Thread Author #2
Anyone else having Swype problems after 2.1 update?
By o2bnclemson in forum Android ApplicationsReplies: 3Last Post: 05-26-2010, 07:50 PM -
Having major problems
By Cirro in forum Motorola Droid Rooting, ROMs and HacksReplies: 11Last Post: 04-04-2010, 02:00 AM -
I'm having a problem with the Gmail app.
By BurgesS in forum General Help and How ToReplies: 1Last Post: 03-05-2010, 07:33 AM -
went into test mode now have screen problem
By ehands in forum Samsung MomentReplies: 1Last Post: 12-30-2009, 09:26 AM -
Does anyone else have this problem or am I just being OCD?
By Jibeker in forum Motorola DroidReplies: 6Last Post: 12-20-2009, 11:34 PM
Reply
