Results 26 to 38 of 38
- 02-17-2013, 02:55 PM #26
- 02-17-2013, 03:57 PM #27
Re: Note II won't stay connected to wifi
AT&T has this Smart Wi-Fi installed on our phones and it is causing some issues for some people. Does Sprint have any of that type software preloaded on the phone too?
Sent from my AWESOME Note 2 - 02-17-2013, 07:36 PM #28
- 02-18-2013, 03:49 AM #29
Someone else said Sprint does have a "Wi-Fi Manager" like AT&T does. Many AT&T users have had to disable that because Wi-Fi won't stay connected or sometimes never sleeps.
Sent from my AWESOME Note 2 - 02-19-2013, 03:41 PM #30
- 02-19-2013, 04:47 PM #31
There is also a sleep or not sleep option setting in "Wi-Fi" then "advanced".
Sent from my AWESOME Note 2 - 02-21-2013, 12:21 PM #32
Thank you. I recently had to do a master reset per request from ATT customer service and remembered I did something like this when I got my phone. I could not remember exactly what it was but this was it. It helped my wifi problems considerably. This was regarding dialing for the menu to turn off power saving on wifi.
Last edited by Starnote50; 02-21-2013 at 12:26 PM. Reason: supposed to be a reply to Kelly, not a separate post
- 03-25-2013, 09:53 PM #33
- 03-27-2013, 10:30 AM #34
(sorry meant to reply with quote)
- 03-27-2013, 10:33 AM #35
- 04-01-2013, 10:09 AM #36
This is the only fix I've been unable to try. When I dial #0011# I get a "connection problem or invalid mmi code" message, which tells me I probably need to root to get to this screen (I don't want to) . Any other way to turn off Wifi Power Save?
I have a problem with my home wifi when the signal is two bars (outside on patio). Every other device out there (my wife's phone, various tablets, laptop) has no problem, but the N2 will continually drop and reconnect. I've even watched it do so while using -- the signal is strong enough, even if two bars, but the connection just drops and then reconnects a few to 10-15 seconds later. - 04-03-2013, 06:25 PM #37
- 04-14-2013, 03:55 AM #38
HP Touchpad/Android won't connect to Wifi
By ZTharakan in forum HP TouchpadReplies: 16Last Post: 11-01-2012, 01:02 PM -
Phone won't connect to wifi or 3g network
By palmer0700 in forum Samsung ReplenishReplies: 3Last Post: 04-25-2012, 12:39 PM -
Can't stay connected to Wifi
By evilhugbear in forum Sprint Nexus S 4G Rooting, ROMs, and HacksReplies: 2Last Post: 03-01-2012, 04:44 PM -
3G stays on while connected to Wifi
By kilofox in forum Droid BionicReplies: 14Last Post: 09-09-2011, 03:50 PM -
Staying connected to Portal WiFi
By mikegeig in forum General Help and How ToReplies: 0Last Post: 05-05-2011, 12:04 PM
Reply
