Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By raju130000
    Default Camera click sound.
    A friend of mine has a Verizon N2 and somehow his camera click sound is off. But I can't seem to figure out how to do it on my sprint N2. The phones are the same so we should have an option. Has anybody figured out how to turn off the click noise when taking a picture?
    Sent from my SPH-L900 using Android Central Forums
  2. #2
    lynnneil's Avatar
    Posts
    Global Posts
    99 Global Posts
    Default Re: Camera click sound.
    You can find in the settings and in the camera options. Select the option to turnoff click sound while taking picture.
  3. #3
    uofmike's Avatar
    Posts
    Global Posts
    65 Global Posts
    I just deleted the noise sounds from the system. If you want them for later, you can just move them to a different folder on a sd card. I believe you have to be rooted to do this though. There are 2 for the video recorder and 2 for the camera (actually I believe there is 4 but I think you only need to delete 2 of them).
    If you are rooted, use root explorer (I'm sure other file explorers will work too, but I know I couldn't find them with ES File Explorer) and go:
    system > media > audio > ui
    the files I deleted are:
    camera_click.ogg
    Camera_click_short.ogg
    Shutter
    Shutter multiple
    and for the video recorder, I deleted:
    cam start
    cam stop
    again, I don't think you need to delete them, just in case you want to put them back, just move them to another folder (might have to be on an external sd)... but I deleted them and have had no problems
    I wish it was that easy there is no option to turn off the sound.
    Quote Originally Posted by lynnneil View Post
    I wish it was that easy.
  6. #6
    chazglenn3's Avatar
    USAF Veteran
    Posts
    Global Posts
    908 Global Posts
    The Verizon, T-Mobile and AT&T versions have a shutter sound toggle in the camera settings...not the Sprint version.
  7. #7
    I use an app called Silent Camera.... and Camera FX. Both do what you are seeking.
  8. #8
    Quote Originally Posted by chazglenn3 View Post
    The Verizon and AT&T versions have a shutter sound toggle in the camera settings...not the Sprint version.
    Why doesn't the sprint version have that? Where in the att and Verizon version can you do it?
    Sent from the Beast that is Galaxy Note 2
  9. #9
    jdod's Avatar
    Posts
    Global Posts
    977 Global Posts
    That is pretty dumb to leave this out.
  10. #10
    tirith's Avatar
    Resident Linux Fiend
    Posts
    Carrier
    Stock Touchwiz LJC 4.1.1
    Quote Originally Posted by yankeesusa View Post
    Iirc, the photon was the first to leave that out... I guess it's so I can't sneakily take naked pics of my fiancee while she's sleeping...
    On a serious note, it doesn't bother me at all so I'm leaving it in.
    Sent from my SPH-L900 using Tapatalk 2
  11. #11
    You also can't take pictures of babies, kids or pets without disturbing them and losing a picture moment. Sure, you can get 1 shot, but that's it. Also, why would anyone really want to try to be quiet about taking pictures during quiet moments like school plays and whatnot.
  12. #12
    jdod's Avatar
    Posts
    Global Posts
    977 Global Posts
    Quote Originally Posted by KahneFan View Post
    Exactly! There are many reasons, this is a bad move.
  13. #13
    tirith's Avatar
    Posts
    Carrier
    I wonder if the stream surrender I had on my photon will work...
    Sent from my G-Note 2
  14. #14
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    Carrier
    Something JB
    It is also against the law in some places to not have the shutter sound to prevent those candid pics.
    That being said, just rename the files above no new to move them.
    Whatever the file name is. Ogg. Bak....... will do the trick. Damn auto correct but you get the point
    Sent from the nexus of the Android world, the SGS3.
  15. #15
    Believe you need root for this.
  16. #16
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    Carrier
    Something JB
    Yes you do
  17. #17
    Again.....silent camera
  18. #18
    I have the TMobile Note 2 and under settings while in the camera there is a toggle to shut off the shutter sound. Its down near the bottom of the list as shown.
    Sent from my SGH-T889 using Android Central Forums
    Attached Thumbnails Attached Thumbnails Camera click sound.-uploadfromtaptalk1356444570706.jpg
  19. Thread Author  Thread Author    #19
    After Diordna11 post it's official only sprint doesn't have the shuttle sound. Is there official samsung forum where we can all complaint so they put it in the next update?
    ghostkilla1388 likes this.
  20. #20
    tirith's Avatar
    Posts
    Carrier
    It's up to Sprint....
  1. Can you silence the camera click sound?
    By PaulQ in forum Samsung Galaxy S3
    Last Post: 08-01-2013, 03:32 PM
  2. Camera Clicking Noise, Shutter Sound Gone
    By HollyDolly in forum Sprint Photon
    Last Post: 08-08-2012, 11:33 PM
  3. Froyo 2.2 Lock Screen Keyboard Clicking Sound.
    By AceBoonKoon in forum Verizon Droid Incredible
    Last Post: 09-01-2010, 01:14 PM
  4. Clicking sound from white EVO's backside?
    By derek5l in forum HTC EVO 4G
    Last Post: 07-19-2010, 09:23 AM
  5. camera makes click sound when turned on
    By jonathanlc2005 in forum HTC EVO 4G
    Last Post: 07-07-2010, 10:32 PM
