1. Grambell's Avatar
    Sometime a thin red lined rectangle flashes around the outside edge of my screen. Trying to figure out what it is. Anyone have any ideas what it is?
    12-20-2012 09:04 AM
  2. Qhaliel Holley's Avatar
    Go to Developer options under settings and unselect Strict mode enabled.
    02-12-2013 01:22 PM
  3. Teresa Marshall's Avatar
    Tried does not stop red ring help.
    03-08-2013 08:28 PM
  4. tirith's Avatar
    Any way to get a screen shot?
    ~swyped from my galaxy note 2 on the now network
    03-09-2013 05:06 PM
  5. Jonathan Jones6's Avatar
    If you have the stock active applications widget on, remove it and you should see the red rectangle go away.
    06-13-2014 10:32 PM
  6. annharp's Avatar
    Screen on phone is a shakey red one.
    07-30-2014 12:38 PM
  7. annharp's Avatar
    07-30-2014 12:48 PM
  8. Curtis Morneault's Avatar
    My g3 was doing the same thing. Turned it off and restarted it. No more red flashing
    02-10-2015 07:12 PM
  9. Curtis Morneault's Avatar
    02-10-2015 07:14 PM
  1. Battery Cover on S3 starting to "Yellow" around the edges?
    By blacknblueberry10 in forum AT&T Galaxy S III
    Last Post: 08-08-2015, 01:00 AM
  2. Red light coming from the proximity light sensor area
    By sndplace in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 01-29-2012, 03:04 PM
  3. Replies: 1
    Last Post: 10-03-2011, 01:01 AM
  4. Replies: 39
    Last Post: 06-30-2010, 11:30 AM
