Results 1 to 8 of 8
- 01-26-2013, 02:14 PM
Thread Author #1
- 01-26-2013, 07:44 PM #2
Re: Why is there no wireless charging for note 2 cdma?
It's not officially supported but Samsung supposedly is going to release a kit for the phone. You can also buy a battery cover that's ready to be used for wireless charging. You can find it on eBay. There's also instructions on how to do it yourself.
Sent from the Beast that is Galaxy Note 2 - 01-27-2013, 03:58 PM
Thread Author #3
I knoqbthey make one for the gsm model which is the do it yourself. If you look at the video you can clearly see there is only 2 pronges in the cdma model. Gsm has 4 pronges. Two for s beam and two for standby. Now younsay samsung will release a kit, will stores like sprint have it? I heard when s4 comes out itll probably hit s3 and note 2. Ill check ebay for the door.
Sent from my SPH-L900 using Android Central Forums - 01-27-2013, 08:11 PM #4
The CDMA only has the prongs for the NFC back; from what I've read, it doesn't support charging. Which is too bad... I was looking forward to doing the Touchstone MOD that I did on my S3.
- 01-28-2013, 04:06 AM
Thread Author #5
So the sprint s3 has 4 pins? I keep hearing they will release a back doors for s3 and note 2. But people dont understand cdma and gsm lol. Hopefully I can find one I been hearing about on ebay
Sent from my SPH-L900 using Android Central Forums - 01-28-2013, 05:34 AM #6
- 01-28-2013, 04:31 PM
Thread Author #7
- 01-28-2013, 04:34 PM
Thread Author #8
Why is there no Aokp rom for the sprint samsung galaxy S3?
By Soundtrack to Chaos in forum Sprint Galaxy S3 Rooting, ROMs, and HacksReplies: 192Last Post: 04-29-2013, 04:29 PM -
Why is there no Samsung Exhibit II 4G Forum?
By rexxcastle in forum AT&T Galaxy NoteReplies: 5Last Post: 04-11-2012, 03:52 PM -
[Help] Why is there no sdcard file on my computer?
By Charlix in forum Optimus V Rooting, ROMs, and HacksReplies: 1Last Post: 03-29-2012, 04:32 AM -
Why is there no way to save emails?
By andonakis in forum Motorola Droid XReplies: 4Last Post: 07-15-2011, 04:44 PM -
Why is there no kickstand?
By Loiselle in forum AT&T Inspire 4GReplies: 20Last Post: 03-14-2011, 08:37 PM
Reply
