Results 1 to 14 of 14
    Default How do you replace power button or turn phone on any other way?
    My phone power button doesn't work how can I turn it on any other way?
  2. #2
    Default Re: How do you replace power button or turn phone on any other way?
    what exactlys wrong with the button?
    Well the phone doesn't turn on. And sprint said I need a whole new button but they don't have the complete button
  4. #4
    gollum18's Avatar
    Posts
    Global Posts
    1,528 Global Posts
    Carrier
    Stock Rooted Mk3
    You could always use adb to power it on, but that would require the use of a computer to do so with.
    If you do want to use it, the command you want is "adb reboot".
    Sent from my paranoid s3...
    What is a adb? And how do I do that?
  6. #6
    If the phone simply isnt powering on its probably not the power button. Generally, like 99% of the time generally, when samsung power buttons go bad they cause the phone to reboot over and over.
    But, if sprint is not willing to help you you should try contacting samsung. If it wasn't physically damaged by you then they should be able to get you fixed up or at least replace it.
  7. #7
    what kind of phone is it?
  8. Thread Author  Thread Author    #8
    I sent it to samsung they said it had corrosion and water damage but I couldn't find any corrosion or water damage on. The phone but I cleaned the whole phone twice once with a brush and the second time I soaked it for like 3 days so I am gonna let it dry out for a few days and see what happens and also try hooking it up to the computer to get it to turn on
    - - - Updated - - -
    It is a galaxy note 2 for sprint it's model l900
  9. #9
    Default
    Quote Originally Posted by Joe Stentiford View Post
    - - - Updated - - -
    Soaked it for a few days? Smartphones should never touch liquid of any kind. Could you tell us more about your cleaning procedures.
  10. Thread Author  Thread Author    #10
    I was told I could soak it in alcohol and then let it dry out but I also noticed under the screen the digitizer is cracked but how can the digitizer crack but the screen be perfect and the case is also mint. Like I said Samsung claims that they found corrosion but I took it totally apart and there wasn't even a speck of corrosion on it
  11. #11
    NEVER heard of soaking a phone to fix it.
  12. #12
    How could you soak a phone to fix a button?
    Sent from my HP Slate 7 using Tapatalk 4 Beta
  13. #13
    Like I said, a phone should never touch liquid of any type. Where did you hear that you could soak it in alcohol? Now I'm afraid that you have broken your whole phone all for a power button.
  14. #14
    Try some silly tricks like plug in to USB/Power and take it out while holding home and volume keys. I have a broken power button and these kindof tricks somehow worked for me a couple of times.
    After taking out from charging sometimes the phone will still show that it is charging. Thats the best time to press n hold power n volume to turn on
  1. How to reorder a playlist manually in Play Music app
    By Calidoc in forum Samsung Galaxy S4
    Last Post: 05-01-2015, 02:17 AM
  2. What is partially charge and should I do that to my battery?
    By trinhtran in forum Samsung Galaxy Note 10.1
    Last Post: 03-18-2014, 01:50 PM
  3. Nexus 7, Nook HD+, or Hisense Pro 7?
    By Angelh23 in forum General News & Discussion
    Last Post: 07-21-2013, 02:44 PM
  4. Data Connection Not Working on Nexus 4
    By AlexanderJJJ in forum Google Nexus 4
    Last Post: 07-21-2013, 05:12 AM
  5. I have a question about esn and programming on a galaxy note 2 or s3?
    By Joe Stentiford in forum General Help and How To
    Last Post: 07-21-2013, 01:13 AM
