Results 1 to 3 of 3
    Default Deep Sleep Battery Saver
    Hi, I was using this application on 4.1.2 software and after a while, it was interfering with my voice mails. I'm running 4.3 software now and would like to install it again, just didn't want more issues. I'm pretty much wanted to know if anyone else uses this application? Other than voice mail issue, I was getting 36 to 40 hrs on a charge using heavy to moderate use.
    USMC97
  2. #2
    wizzrah's Avatar
    Posts
    Global Posts
    2,696 Global Posts
    ROM
    CodefireX One XL 4.4.2
    Default Re: Deep Sleep Battery Saver
    Quote Originally Posted by kanesmith41 View Post
    USMC97
    I did at once, but I don't have it on my phone.
    I do however recommend
    It's similar to battery saving apps, but with a twist. Check it out.
    It is our choices, that show what we truly are, far more than our abilities. - J. K Rowling
    "If you love life, don't waste time, for time is what life is made up of." - Bruce Lee
    "The story of life is quicker then the blink of an eye, the story of love is hello, goodbye." - Jimi Hendrix
    Thanks, I'll check it out.
    USMC97
  1. Note 3 Battery Thread.
    By Amir in forum Samsung Galaxy Note 3
    Last Post: 01-30-2014, 09:14 AM
  2. Keeps showing battery indicator on boot
    By Zergslayer69 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 01-03-2014, 06:45 PM
  3. Battery Replacement
    By ic3pO in forum Droid RAZR MAXX HD
    Last Post: 01-02-2014, 04:18 PM
  4. Replies: 10
    Last Post: 01-02-2014, 12:29 PM
  5. Replies: 5
    Last Post: 01-01-2014, 11:48 PM
B
