Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By UJ95x
    Default GSam Battery Monitor
    Hi, I installed this application and I noticed Facebook was awake 290 times and Samsung push 271 and android system 218 times. Those are the most applications that awake that much. Just wondering if that's normal? Any suggestions would be appreciated.
    USMC97
  2. #2
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Default Re: GSam Battery Monitor
    Quote Originally Posted by kanesmith41 View Post
    USMC97
    Is it draining your battery? If so, you could prevent Samsung push and Facebook from doing this by setting the refresh or notification interval to manual, rather than push.
    I don't use the apps so I wouldn't know if it happens often, but they seem to common and easy to fix for the most part.
    B. Diddy likes this.
  3. #3
    Those wakelocks don't seem abnormal. What's more important is how much battery they're reported as using. But I agree with UJ95x--changing refresh intervals to manual (or to the longest interval available) will cut down on the number of times that an app will wake the phone up to do something (like checking the web to update data).
    It's not draining the battery. I can usually get 30 to 36 hrs using it moderate . I've got Facebook to sync every 6 hours. Just a little curious about it. I'm trying to learn this GSam Battery application. Thanks for the feedback.
    USMC97
  1. Nexus 5: Battery Very Inconsistent - What's the culprit?
    By onthecouchagain in forum Google Nexus 5
    Last Post: 09-17-2014, 04:05 AM
  2. About battery drainage.
    By Amir in forum Samsung Galaxy Note 3
    Last Post: 02-01-2014, 10:39 AM
  3. nexus 7 battery tips
    By iDoc86 in forum Google Nexus 7 Tablet (2013)
    Last Post: 01-16-2014, 10:29 PM
  4. False Battery Reading When Charging
    By stimulatedboredom in forum Verizon HTC One
    Last Post: 01-16-2014, 09:19 PM
  5. Screen flicker and phone crash? Battery issue?
    By rachmarb in forum Samsung Galaxy S3
    Last Post: 01-16-2014, 06:09 PM
