1. Es Es's Avatar
    Dropped my phone and now the screen won't turn on. Everything works, I can answer phone calls by swiping and end the call by pressing the end button but the screen won't turn on.
    Will a new screen fix this or is this an internal issue?
    If it is internal, is it an easy fix or will I need to order parts?
    Please no generic responses ie. "send it in for repair" or "do you have insurance." If you don't know of this issue please don't respond.
    Thank you!
    01-22-2014 06:06 PM
  2. Golfdriver97's Avatar
    The hard thing to say about this issue is what else may have been damaged in the fall? Obviously the screen, but what other hardware/ribbons/connectors etc? It is hard to depend on a visual inspection because there are many times where chipsets look fine but aren't running properly.
    Even if it is just the screen, replacing that alone can be tricky. Other parts can be damaged when trying to remove the screen.
    01-22-2014 11:48 PM
  3. Es Es's Avatar
    I have done a screen replacement before and plan on doing another one next week (I just ordered another screen replacement). I am just wondering if a cracked screen can be the cause of the screen not turning on. It was cracked much more severely before I replaced it previously and the screen was working fine. What illuminates the screen?? I don't think the digitizer does...
    I did do the recent update before I dropped the phone. I heard of people having a similar problem after updating then dropping their phone.
    01-24-2014 08:48 PM
  4. Golfdriver97's Avatar
    I am going to be honest, I am not sure about how a smartphone works, physically.
    01-24-2014 10:02 PM
  5. cjb717's Avatar
    Did you ever find out what was wrong? I am experiencing the same problem at the moment
    07-26-2014 10:43 AM
  1. Which phone should I get for grandmother in Ukraine
    By LeoBloom. in forum General Help and How To
    Last Post: 12-23-2014, 06:43 AM
  2. most anticipated phone.
    By Anon8154066 in forum General News & Discussion
    Last Post: 04-16-2014, 04:34 AM
  3. Groupon Deal for Refurb Note 10.1 2014
    By dsw1519 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 01-23-2014, 12:50 PM
  4. Disabling new "multi widgets update" on lock screen on S3
    By Mariposanena in forum Verizon Galaxy S III
    Last Post: 01-22-2014, 05:03 PM
  5. Samsung Galaxy Note 3 Wifi Problem Solved!!!
    By nayan350 in forum Samsung Galaxy Note 3
    Last Post: 01-22-2014, 03:54 PM
