Results 1 to 7 of 7
    Default Battery charges slow and discharges fast
    I'm noticing that in addition to slow 4G service, I'm getting really bad battery life. My standard battery discharges completely in about two hours and can take up to 8 hours to recharge. Has anyone else noticed this or had a similar issue? If so, hire did you rectify it?
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,719 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Battery charges slow and discharges fast
    Quote Originally Posted by dbarnes2270 View Post
    I don't think this will help, but you can give it a try: Reboot into recovery and clear cache. Here is how: [Guide] Rebooting into Recovery Mode for the Galaxy S2, S3, and Tab2.
    Follow instructions for the S3.
    I tried that and it didn't really change anything with regard to the battery usage. Your link just took me to a forum thread about the S3. Any other suggestions?
  4. #4
    mchi5's Avatar
    Posts
    Global Posts
    861 Global Posts
    How long have you had your Note 2? May be a dying battery?
    Do you know anyone with a Note 2 that you can swap batteries with and test this theory?
    Sent from my Samsung Galaxy Note 3 via Tapatalk
  5. #5
    Theot's Avatar
    Posts
    Global Posts
    321 Global Posts
    Carrier
    Whomp 4.2/Perseus 36.3
    I was having major battery life issues on mine after 15 months of use. Bought an anker stock replacement battery on Amazon for $15 and it's like new again. I'd just spend $15 for a new battery.
    Sent from my SPH-L900 using Tapatalk
  6. #6
    Yeah, your battery needs to be replaced. They are only good for 500 cycles and then they start to go bad. I had this problem until I replaced the battery and now it's like a new phone again.
    From my Note 2 to you
  7. #7
    try a new cable. those are cheap. and try a new battery. batteries don't last forever. i'm ALWAYS replacing battery half way through my ownership timeframe.
  1. Forgot Pin on Galaxy S5 and locked out?
    By brandonzak in forum Samsung Galaxy S5
    Last Post: 10-19-2016, 02:54 AM
  2. battery since kitkat upgrade
    By Amir Hadanny in forum LG G2
    Last Post: 05-26-2014, 10:44 AM
  3. Access and rescue data on a dead screen unit?
    By IllusionSector in forum AT&T Galaxy S3
    Last Post: 05-17-2014, 11:21 AM
  4. Replies: 0
    Last Post: 05-17-2014, 02:26 AM
  5. New GS4 and New on Verizon
    By Sgooter in forum Verizon Samsung Galaxy S4
    Last Post: 05-17-2014, 12:17 AM
