Page 1 of 2 12 LastLast
Results 1 to 25 of 26
    Default Magic Color / Wifi Led Controller
    Hi folks,
    Did a quick search and found no direct hits for my issue. I have a Wifi led controller and the supplied android application Magic Color V1.0. When started it prompts me with a message that my phone is not connected to the controller via Wifi. I am connected , i tried to remove/reinstall with the same results. It also came with an apple OSX version which i installed on an ipod touch and it worked from the start. I'd rather use my Note 2 with the large screen instead. I am current rooted running 4.3 Anyone else have any luck getting Magic Color to run? Any suggestions would be greatly appreciated. Thanks
  2. #2
    Default Re: Magic Color / Wifi Led Controller
    Are you talking about the LED magic color controller v2?
    Its actually called Magic Color. I've seen Led Magic Color but that program will not work with this controller. The developer also built Dream Color for OSX and has ported Magic Color over as well. I've downloaded both for the ipod and they both work, but i would rather use his android version for my note2.
  4. #4
    I just moved from the iPhone 5 to the Samsung Galaxy S5 Active and cannot get neither Magic Color 1.0 (from the disk that came with the Wifi to control my Oracle Halos on my car) NOR Magic Color 2.0 (from Google Play) to work. I am connected to the LN001 network and it gets an IP but neither app will work. It worked on my iPhone. I sure hope we can find a solution.
  5. #5
    Hello, I just bought this Wifi LED Controller and I'm having the same problems. I also can't turn off the simulation switch. Has anyone here found the solution?
    Thanks.
  6. #6
    Problem solved!!!
    Hey all. I had the same problem. Talked to the manufacturer Shenzhen Leynew Technology Co., Ltd about the issue. They sent me a newer version of the app called MagicColorV2. Works like a charm. (yes, I know we're not talking about LED Magic color)
    I have attached the new version to this post (I hope). Let me know how it works out.
    Attached Files Attached Files
  7. #7
    Anyone able to get the more advanced version working with a Galaxy Android? The version where you can create custom modes? Thanks!
  8. #8
    THANK YOU!!! IT WORKED! Finally! I had to remove (Uninstall) the Magi Color 1.0 and then installed the one you attached and it worked like a champ. You have to turn off the simulation mode (in setup, as it is on by default). U R DA MAN!!!! Thank you! Thank you!
  9. #9
    I can't find this file link. Help me, please.
  10. #10
    thanks, I just installed this on a note 4, works great.
  11. #11
    I can not see the wifi. the first time I found it, but then disappeared. I tried with others but always the same problem.
  12. #12
    I don't see the attachment
  13. #13
    I downloaded them to my laptop and transferred to my Galaxy S5, now it works like a champ, thank you!
  14. #14
    attachment file again.
  15. #15
    So how do i connect to the wifi controller anyways? Instructions has me so lost...
  16. #16
    I can't open the attachment. Can you resend to me? Thanks
  17. #17
    seem good
  18. #18
    we are the manufacturer of it. you can search WiFi370 led controller.
    www。ledwificontroller 。com
  19. #19
    I hope someone is still paying attention to this thread. I just bought the WiFi300 controller and have a Samsung Note 4. I'm searching with the phone trying to find the android Magic Color V2 download for the phone app. My computer is a Mac Pro and I can't open the application on the CD disc that came with the controller. Does anyone have please the exact link where you were able to find the Magic Color V2 download for your recent model Samsung phone?
  20. #20
    Send me a message and I'll give you the link from my drive.
  21. #21
    Thanks very much. Just saw your prompt reply only a little while ago. Sent two messages but seems that only the 2nd one is showing up. Hoping to get the link sent to my email address so I can also open it with my phone and go directly there to find the download and do it.
  22. #22
    Just messaged jswagmore6722 if I can plz get a link
  23. #23
    hello
    i use the v2 app also and i am able to connect fine to led controller but my issue is that the controller can not connect to my router.
    i vahe tik the link option , put the right pass but then it restarts and still nothing.
  24. #24
    Can you attach the link for the app again.
  25. #25
    Anyone have the file or app that works?
  1. Wifi won't turn on; MAC address unavailable
    By Roger Brienza in forum Google Nexus 7 Tablet (2012)
    Last Post: 12-21-2016, 02:19 PM
  2. White color on my Nexus 7 2013 screen not perfectly even!!Is this normal?
    By Aditya Shanbhag1 in forum Google Nexus 7 Tablet (2013)
    Last Post: 06-11-2014, 08:28 PM
  3. 4.4.3 update changed phone dialer color
    By Double Tap in forum Google Nexus 4
    Last Post: 06-11-2014, 10:44 AM
  4. Contacts icon color, is it random?
    By fredo166 in forum Android 4.4 KitKat
    Last Post: 06-10-2014, 07:01 PM
  5. Replies: 0
    Last Post: 06-10-2014, 01:47 PM
