False battery drain...
Drummerboy1975
252
4
18
Twice now, my phone is running fine, with about 30-50% battery life left, when all of a sudden, it shut off. When I power it back up, it say I have 0-3% left, and it will stay on for only a few seconds, then powers off again. I then have to either remove the battery or plug it in. Then it will power back you and show that I actually have the 30-50% left.
Anyone else experience this?
regression
252
4
Yep, happens to me every now and then. It is one of the "features" Sprint / Samsung gave us with the ICS update.
ScottMGS
541
Sounds like it could be a bad battery.
---------- Post Merged at 08:09 PM ---------- Previous Post was at 08:09 PM ----------
patrao_n
364
51
As far as the phone turning off I would check for a bulging battery. Take it out and sprint it on a flat surface on the flat side. Filp it and spin it on the other side. If it spins like a top then its a bad battery. Also does it wiggle in the phone? Is the back hard to put on? All these are signs of a bad battery. If when you turn it on its really low and then a reboot fixes it its either a bad battery it its just the ics software. Even with a good battery it will do this. Usually its only 10 or 20% tho.
sent from my BAD A$$ Epic touch
Brainerd
283
11
This happened to me. Turns out my battery was at its end of life. I bought a new OEM battery on Amazon for ten bucks and now my phone works fine. Completely eliminates the problem you are having.
rtd13
Active member
Feb 17, 2011
36
www.rondubinphotography.com
It didn't happen after the upgrade, things were great, it just started happening to me all of a sudden. The thing is, it only happens when I open up Chrome.
After about a minute or two, I get a black screen and the sign off music. When I reboot, it has the correct battery life %.
Guessing it was a bad Chrome update last week or some other app conflict because all was great.
Cobravision
1,271
40
48
It sounds like a bad battery. Take it out, lay it flat, and then spin it. If it spins around like a top, it needs to be replaced.
fallguy
Good call on the battery. I took mine out and it spun like a top. I also rooted and went back to El29 Gingerbread and the first day I was back to 15 plus hrs on this crappy battery. New battery will be here today.
HubMal
Thanks to you, guys! Spent over 2 months having very similar problems, without managing to troubleshoot the issue (I thought it was software-related). I followed this lead as the last resort before changing the handset. Turns out it was the battery. THANKS A LOT.
Finsrepair
