- 10-03-2012, 09:20 PM
Thread Author #1
Power noise
I have my phone connected to my aux input in my car. Works great. However, if I plug in the car charger, there is a loud hum coming though the car speakers. I have tried a different charger but the same results.
Has anyone run into this before? Wondering if there is a filter is could get to eliminate the noise. Thanks.
Sent from my Nexus 7 using Tapatalk 2 - 10-04-2012, 12:47 AM #2
Re: Power noise
Is your stereo grounded correctly? I have no problems using mine. Hooked up to my eclipse with one of the newer pioneer radios. Also check your ground where your cigarette lighter hook up is. Wish I knew more to help you.
sent from my BAD A$$ Epic touch - 10-04-2012, 12:48 AM #3
Re: Power noise
Is there any hum when just using the cat charger and not hooking it up through auxillary?
sent from my BAD A$$ Epic touch - 10-04-2012, 07:04 AM
Thread Author #4
- 10-04-2012, 07:16 AM #5
- 10-04-2012, 08:06 AM #6
Re: Power noise
It may be your auxillary cord. Although if two of you have the problem then its likely interference. You would need a filter between your phone and the unit. I have never needed it so I couldn't tell you which one. Goodluck guys
sent from my BAD A$$ Epic touch - 10-04-2012, 12:47 PM
Thread Author #7
Re: Power noise
I may pick up something like this and see if it fixes the problem:
Amazon.com: PAC Ground Loop Isolator for 3.5 MM Applications: Car Electronics - 10-05-2012, 06:14 PM
Thread Author #8
Re: Power noise
I got this in the mail today:
I works like a charm. The annoying hum is gone.Thanked by 2: - 10-06-2012, 08:36 AM #9
- 10-07-2012, 07:14 AM #10
- 12-30-2012, 05:31 PM #11
- 12-30-2012, 06:45 PM
Thread Author #12
- 12-30-2012, 07:52 PM #13
- 12-30-2012, 08:01 PM
Thread Author #14
Re: Aux noise
Hmm, sounds like there is a problem with the stereo. This isn't too expensive. You might try it to see if it solves the problem:
PAC Ground Loop Isolator for 3.5 MM Applications : Amazon.com : Automotive - 12-31-2012, 08:52 AM #15
- 12-31-2012, 09:27 AM #16
can you turn off the annoying DROID noise when phone powers on?
By jsbrendog in forum Verizon Droid IncredibleReplies: 7Last Post: 09-03-2010, 02:53 PM -
background / ambient noise issue
By Soobs in forum Motorola DroidReplies: 9Last Post: 11-24-2009, 01:03 PM -
Sleep/Power
By trentandrews in forum Motorola DroidReplies: 2Last Post: 11-24-2009, 10:25 AM -
Change volume of keypress noise
By Aelther in forum Motorola DroidReplies: 2Last Post: 11-16-2009, 02:40 PM -
Keep Hero 'ON' while powered
By garrilla in forum HTC HeroReplies: 2Last Post: 11-16-2009, 01:09 PM
Reply
