Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 51
Like Tree5Likes
  1. #26
    LS14EVR's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Strange Battery Problem - Need Help
    Just want to add that my battery is a little over a year old and I was one of the first to do the upgrade to 4.0.4 that had all those early issues. High battery drain in particular. I think that is what really killed mine prematurely. At any rate, I'm still rocking GB and it had been fine, but as of lately my phone was complete junk! I kept getting the task manager popping up. Slow to respond, screen flicker and apps closing, losing signal, you name it. My battery had the buldge. I bought a Samsung direct replacement, same exact battery from Amazon for $15 shipped. Popped it in last night and my phone is back to it's old snappy self. Perfect! So far. I'll keep you all posted, but I now love my phone on GB all over again! So if you have issues, get a new battery!
  2. #27
    mfsanso's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    FD24
    Just got the $15 genuine Samsung replacement battery and I was very disappointed with its performance. Here are three screenshots comparing the replacement 1800mAh battery (first screenshot) to the 3800mAh battery (second and third screenshot - both high intensity use and practically idle all day)
    I'm sticking with the higher performance/capacity battery until my next phone...
    Attached Thumbnails Attached Thumbnails Strange Battery Problem - Need Help-uploadfromtaptalk1354645638290.jpg   Strange Battery Problem - Need Help-uploadfromtaptalk1354645666137.jpg   Strange Battery Problem - Need Help-uploadfromtaptalk1354645800426.jpg
  3. Thread Author  Thread Author    #28
    lancehart's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Replaced my battery... happy to say that the problem was solved. My old battery spins like a top, and compared to the new battery, you can see the bulge very clearly now.
    Make me wonder if Samsung had a bad batch of batterys when they launched the Epic Touch. Makes no sense that so many of these are suddenly going bad all at once in the same basic timeframe of
    about 12-14 months after purchase.
    LS14EVR and hany53 like this.
  4. #29
    JayWill's Avatar
    Posts
    Global Posts
    2,636 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by lancehart View Post
    Hard to say. Maybe it was bad QA. Maybe it has something to do with ICS. Maybe it's the thin plastic backing and environmental exposure issues. It could be a number of possibilities.
    My new battery came today and all is well again. Although I'm pretty sure these $16 "OEM" batteries on Amazon are Chinese knockoffs. We'll see how this one performs over time.
    Sent from my SPH-D710 using Tapatalk 2
    LS14EVR likes this.
  5. #30
    HooperD's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  6. #31
    HooperD's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Wow - that was surreal. I was responding to a string about an Epic Touch battery. I posted, then scrolled to the top, and it was a different string.
  7. #32
    Riboflavin's Avatar
    Posts
    Global Posts
    268 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Had this exact problem. Never had any battery issues until the JB upgrade. Tried Factory Reset and that didnt help.
    I bought a $10 OEM Samsung battery off Amazon. Put it in last night. Phone works fine. No crash when using GPS with medium-high screen brightness. Old battery spun like a top.
    Gonna hold me off 2 months until i upgrade to the S4
  8. #33
    Devish Laroiya's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    my S2 just shuts off without any notification and doesn't start until i plug it to the charger and switch it on. This mostly happens after 2 minutes of playing games,listening songs or downloadin an app. What should I do? Please help me
  9. #34
    srkmagnus's Avatar
    Posts
    Global Posts
    13,762 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Quote Originally Posted by Devish Laroiya View Post
    You need a new battery. I'm using An Anker battery from Amazon and it works great.
    Golfdriver97 likes this.
  10. #35
    vitrap's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Lightbulb Re: Strange Battery Problem - Need Help
    The same problem after 2 months of using a new phone with a new battery (I suppose at least).
    I have a theory:
    Something tells me, that it is caused by the car charger. My troubles started after buying and starting to use the car charger. I see the same experience all over this discussion. Could it be, that the car chargers could damage the IoN batteries? May be due to bad stabilization of charging voltage/current?
    Someone could check it out? Is there anyone, who face the same problem without using any of car charger or any other doubty charger?
  11. #36
    Tim_Schroeder's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My phone is a HTC Desire S, which I upgraded to Android 4.0.4 a few months ago (official update). The shutdowns and extreme power drainage startet about a week ago. With a full battery my phone reliably shuts down less than 5 minutes into a game. Then upon reboot it reports ~6% battery life and often shuts down again.
    I just took out my battery and saw a little bulge on one side. Though the bulge is not yet big enough to let the battery spin easily, I think I'm having the same problem you guys mentioned. I will probably try with a new battery.
    Quote Originally Posted by vitrap View Post
    I never used a car charger. Instead I use either my PC or the official charger that came with the phone.
    edit:
    The new battery solved my problem.
    Though I wonder what caused my battery to fail. Maybe it got too hot during summer? I remember playing games on my phone a few weeks back and the phone got really hot (but it didn't shut down, therefore I thought it wasn't too hot). Or maybe it was just too old after 2 years of usage?
  12. #37
    xerofailgames's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i currently have these same issues with a samsung galaxy player....here is the forum cause im to lazy to retype everything....hi names xero
    i already got one battery and it did it again...though that battery could have been used as well...i also ordered an anker battery waiting for it to arrive...
  13. #38
    srkmagnus's Avatar
    Posts
    Global Posts
    13,762 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Quote Originally Posted by xerofailgames View Post
    See of the Anker provides and better results. I had to Anker batteries with my E4GT and it worked great.
  14. #39
    Kevelade07's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That's the battery. Had the same problem with my SGS2. I charged it, used it for a while, and around 50% the phone just shut down. Smashed the battery a couple of times on the floor, and it re-worked again, but for like 15 minutes. I changed the battery and it works just fine since then!
  15. #40
    KS37's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi the problem is because you over charged your phone that's why is swollen.
  16. #41
    WeLoveDallas2's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    thanks for this info ive been looking for days as having the same problem with phone i just took my battery out & its spinning like a top im going to go & replace battery hope it works
  17. #42
    rcunningham's Avatar
    Posts
    Global Posts
    232 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I also have the same problem on my LG Ally. I downloaded this root app for xposed frameworks so it never shuts down intull the phone has nothing left in it. So it does not shut down at 1% it shuts down when there is nothing left. It's the best app I have had on my LG Ally!
  18. #43
    Harsh Sears's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This has happened to me once with my HTC Wildfire so I simply bought another battery for my phone - this actually helps.
  19. #44
    SebsMech89's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hello guys. I'm experiencing this same issue since this morning. I found my phone turned off in my pocket, but didn't pay too much attention to it. Later, I was Skyping via 3G for about half hour and suddenly audio started to fade, and when I checked my phone, signal whas showing the simbol Ø. After rebooting foud out that battery was dying, so connected just to say goodbye and went to lunch.
    After lunchtime, looked at my phone and realized that battery has been misteriously recharging. Plugged my phone at the office, and rebooted a couple of times. Below you will see the charging timeline, after removing and reinserting the battery, level seems to increase (see last bit)
    What's courious is that battery level seems to drop a little after booting the phone. After reading this thread assumed that I need to replace my battery (got my phone a little over one year ago), even if it doesn't "spin" when in the table, and both sides are completely flat, but I think it was interesting to show this to you guys.
    For the last two months my battery has been taking a little too much, because signal here is really low, and I need to keep my phone plugged to my office laptop all the time.
    Regards,
    Sebastián
  20. #45
    Jerral's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm using a Sony Xperia Z1 and recently i'm dealing with a weird problem that has something to do with my battery..
    I'd have it at 85% and when i lock the screen and leave it for say around 10 minutes, then when i unlock my phone again, it would show 45%..
    And sometimes, it gets worse, from 74% it can just suddenly die off to 0%..
    Another thing is that it charges very irregularly, at first it will be 20% but after just 5 minutes on the charger, it would mysteriously shoot up to 75%..
    Would really like to know what's going on and how to solve this
  21. #46
    ratzyy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    ok i understand that battery bulge thing, thing is what if there is phone with NON-REMOVABLE battery like sony xperia then??
  22. #47
    ratzyy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    same problem my friend..... i can understand the pain
  23. #48
    rassel1974's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Automatic shut down problem of J7
    My Galaxy J7 suddenly shut down, and could not restart by pushing the power button. I need to pull out the battery and after again attach the battery then it take start. It is happening after 4/5 days frequently.
  24. #49
    andrews bruno's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: - Need Help
    My mobile switches off even at 70-80% of charging.and it doesn't switch on even when I switch it on.after plugging it to the charger it shows the same battery level as above.it switches on when after I plug it to the charger only.it switches of at 60-70% and shows 0% charge level.later it shows 40-50% of charging.it happens every day usually with no timings.when I use my mobile it switches of after some time.i got it repaired the man said it was a software problem.he had done it.even though it is as usual.later he said it was memory card problem and also said to format it and use.ive done the same.but no use.can I get any help.
  25. #50
    B. Diddy's Avatar
    Posts
    Global Posts
    77,987 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Welcome to Android Central! This is a really old thread in the S II Epic 4G Touch forum (man, those old names were just horrible ), so you might want to create a new thread with your question, preferably in the subforum for your particular phone (if available).
    Offhand, I'd suspect a problem with the battery. Did you also replace that?
  1. Strange battery lately... Need replacement?
    By JacobMiW in forum HTC EVO 4G
    Last Post: 04-13-2011, 01:31 PM
  2. FROYO and Keyboard Problem - Need Help
    By buckifvr in forum Verizon Droid Incredible
    Last Post: 08-31-2010, 05:07 PM
  3. Phone starting in Speaker mode problem - Need Help!
    By Redraider1 in forum HTC EVO 4G
    Last Post: 08-22-2010, 11:39 PM
  4. serious problem need help
    By blunt420 in forum Verizon Droid Incredible
    Last Post: 07-02-2010, 12:49 AM
  5. Serious problem need help
    By jbg21 in forum HTC Droid Eris
    Last Post: 01-14-2010, 09:57 AM
