- 11-13-2012, 10:51 AM
Thread Author #1
- 11-13-2012, 12:06 PM #2
Re: Strange Battery Problem - Need Help
What you're seeing is the way fuel gauge works on this phone. The gauge is designed to converge towards the "true" battery level over time, which is why the battery on this phone doesn't need calibration. However, sudden unexpected shut offs can throw the gauge off, which is why your graph falls off a cliff on the reboot. Then, the gauge converges with the true battery level, which is why the battery level moves higher, even when unplugged.
Sent from my SPH-D710 using Tapatalk 2 - 11-13-2012, 01:51 PM
Thread Author #3
That makes sense for why it showed a rise in power after the reboot, but my real concern is why did the phone shut off and die on it's own with over 80% battery power remaining (after a full night charge) and when I reboot it the first time, it only had 1% power, and shut off again. Only after I removed the battery for 2 minutes and put it back and rebooted it again did it come back to life, reporting a 50% charge.
A little more of an update, I've kept it out of the charger, and at 2:30pm, with 40% power on the meter, it shut off dead again.
I pulled the battery and restarted... only to discover it was at 1% power again and on the verge of a true power shut down.
Now the fuel gague could have still been messed up, but it seems to me that my battery is shorting out or something, even when near full power,
there is no way I can explain the huge chunks of power loss, or shut downs that I've never experienced before this week. - 11-13-2012, 02:57 PM #4
This EXACT same thing happened to me. I was playing a stupid game and the thing would just shut off. I would power back on within seconds of it power down and it would booth to 0% battery and then shut off again. After 2-3 minutes of letting it rest, it would power back on but instead of being at 85% battery or so, it would be at 40%. If I were to do ANYTHING, even simply pull up the app drawer, it would shut off - no animation shut down, just black screen off.
I assumed it was my battery health. I've been whaling on it pretty hard the last few months because I got so frustrated with not being able to use the GPS on my drive home without draining the battery (even while using my old 600mA car charger) so I bought a 2A car charger and was able to actually charge the battery while using the GPS on my drives to and from work. Luckily I had bought a 3800mA battery a while back and I'm using that until I can get to the true bottom of the issue here. I'm going to try to "restore" my battery by letting it slow drain over night and then slow charging it. I hope a few cycles of this will help restore the battery to good health (even though all my battery apps tell me the battery is in good health).
By the way, the 3800 mA battery lets me use my phone as I want all day and I still have 20% battery life at the end of the day; bright screen, WIFI on all day, GPS on all day, two 45 minute GPS trips, checking email, streaming radio, googling randomness, the whole nine yards. I love it. The only draw back is that it is fatter and requires a bumped out back cover (included) but I think it makes the phone slightly easier to hold in one hand. Just my own opion. Not bad for $17.
Amazon.com: Samsung Galaxy S II (Sprint) Epic 4G Touch SPH-D710 Extended Battery with Door Black 3500mAh: Cell Phones & Accessories - 11-14-2012, 03:12 PM
Thread Author #5
This is getting to be a more serious problem... At first there was a few days between it happening again, yesterday when I wrote in, it happened twice in one day for the first time.
It happened again this afternoon... while not even using an intense battery draining app like GPS, I was just browsing with Chrome with about 70-80% power before it crashed.
Rebooted to find only 4% power... and it shut down again less than a minute later. Without turning it on or taking the battery out, i plugged it in to find it showing only about 40% power,
which climbed back up to 74% after 15 minutes of powered down charging before I turned it back on.
I'd hate to spend money to get a new battery, only to find out that the problem may be related to the hardware in the phone instead.
Though it never happens (yet) when the phone is plugged in either in my car, or in my desk dock at work, which is why I was leaning towards
it being a battery issue. - 11-14-2012, 04:43 PM #6
Take your battery out and spin it on a flat surface. If it spins rather easily you probably have a bulging battery and need a new one. If it doesn't, I suggest you first try a factory reset, and if the shut downs continue, take it to a Sprint tech center.
Sent from my SPH-D710 using Tapatalk 2 - 11-14-2012, 07:27 PM #7
I've had the exact same problem since last week and has increased in frequency as well.
My son has an SII too, so I swapped out batteries to see if it's the battery or the phone. Phone seemed to function without issue having his battery in there, so looks like I will go with a new battery.... Oh well - 11-19-2012, 01:56 PM
Thread Author #8
- 11-19-2012, 09:25 PM #9
My wife's phone is having the exact same problem. I swapped our batteries to see what happens. I'll report later.
- 11-19-2012, 09:35 PM #10
Please keep us posted on the issue; I'm curious to know if a new battery solves the problem.
- 11-19-2012, 10:14 PM #11
So her battery is now in my phone. It was charging and according to the phone it was 100%. Pulled it off the charger and it immediately indicated it was at 90%. So far after 15 minutes it still says its 90%. I'll keep watching it let you guys what happens.
My wife's phone, which has my battery is acting normal for now. Again, I'll keep monitoring. - 11-20-2012, 07:30 AM #12
woke up with 12% of the battery left with nothing obvious running in the background, although the battery says android OS used up 66% of the battery while I was sleeping. My phone does do this from time to time. So far nothing out of the ordinary. I'll have to talk to my wife at the end of the day to see how her phone is holding up.
- 11-20-2012, 09:58 AM #13
- 11-20-2012, 05:18 PM #14
Yup, its the battery. I had it on the charger up until a few mintues ago. Decided to play a game during some downtime, and after about 5 minutes the phone crashed. Turned it back on and when it booted up, I unlocked it and the battery meter read 20% (down 80% in 5 minutes of playing a game). Not only that but the screen looked like it was starting to flicker (like it was running out of juice) and crashed again. Turne dit back on again, now it says its at 69% and acting normal.
Looks like its time to replace the battery all together. - 11-20-2012, 08:40 PM #15
- 11-21-2012, 07:23 AM #16
Wow, I've found a surprising development. After reading JayWill72's suggestion and reading about swelling batteries, I took a closer look at mine and low and behold, not only did my battery spin on my desk, but it was visibly swollen, as discussed in THIS thread. I'm thinking now that as the battery gets put into high demand and begins warming up, the swelling disconnects it from the prongs and that's why we're getting the blackout crashes. I may try replacing the battery to see how well my phone performs on an brand new stock battery.
Any suggestions as to where to buy an authentic SAMSUNG battery?
Anyway, here are a few pictures of my battery - one while its spinning, one showing the actual bulge and two showing the corners of the battery not touching the desk surface. - 11-22-2012, 11:25 PM #17
- 11-23-2012, 10:58 AM #18
I got my battery here:
http://www.amazon.com/gp/aw/d/B005LB...idcentral00-20
Price went up a few bucks since I got it tho. It arrived very quickly.
Sent from my Galaxy S II - 11-26-2012, 11:25 AM
Thread Author #19
At first I didn't think it was bulging, but looks like mine has the same bulging battery problem that is going around like wildfire lately. Spins like a top too. Waiting for a new battery to fix the problem, or will sprint replace it for free with insurance?
- 11-28-2012, 02:54 PM #20
Well, you can add me to the list for the great battery bulge epidemic of 2012. I've experienced a few random shutdowns recently and upon reboot the battery gauge is zero followed by another shutdown. I checked the battery and mine is indeed starting to bulge on one side. Strange that this issue has become so common.
Sent from my SPH-D710 using Tapatalk 2 - 11-28-2012, 06:22 PM #21
What I'm interested too know though, is why does the screen flicker and shut off,but right before I completely lose my signal? Actually, lately my phone just drops the signal for no apparent reason. I have absolutely never ever had this problem??? So what gives? I will like to add that I was one of those guys saying how I love my phone so much and wouldn't have changed a thing from eg30. Went to FI27 to hopefully get better gps just to regret my decision later. Now I've odin'd back to eg30 and the problem I picked up while on/from ics exists still. Ordered battery will do a report soon too.
- 11-29-2012, 12:22 AM #22
- 12-03-2012, 08:21 PM #23
I am having the same problem. Started about 2 weeks ago, but has been getting worse. Same version/build. I have noticed that when I plug back into the charger, and restart the phone, I have service connection, though I can turn on the wifi and it connects fine. I have to pull the battery to get full functionality back.
Well, now that I posted, I went back and read the latest posts and decided to check my battery. I spins like the proverbial top, both sides.Last edited by bernmeister0; 12-03-2012 at 08:33 PM. Reason: skipped over some posts and when I went back to read them, I checked my battery
- 12-03-2012, 09:58 PM #24
Yeah I've come to the conclusion that service dropping, screen flicker, random shut downs, apps like the browser closing by themselves, etc, are all related to the battery going bad.
Sent from my SPH-D710 using Tapatalk 2 - 12-04-2012, 07:17 AM #25
Strange battery lately... Need replacement?
By JacobMiW in forum HTC EVO 4GReplies: 2Last Post: 04-13-2011, 12:31 PM -
FROYO and Keyboard Problem - Need Help
By buckifvr in forum Verizon Droid IncredibleReplies: 4Last Post: 08-31-2010, 04:07 PM -
Phone starting in Speaker mode problem - Need Help!
By Redraider1 in forum HTC EVO 4GReplies: 4Last Post: 08-22-2010, 10:39 PM -
serious problem need help
By blunt420 in forum Verizon Droid IncredibleReplies: 16Last Post: 07-01-2010, 11:49 PM -
Serious problem need help
By jbg21 in forum HTC Droid ErisReplies: 1Last Post: 01-14-2010, 08:57 AM
Reply
