Results 1 to 5 of 5
- 11-20-2012, 01:34 PM
Thread Author #1
will rooting help or fix GPS issue?
Sorry if this has been addressed before. I have major GPS issues where it just won't lock or take ridiculously long to get a lock. I've had the phone for a year and it's always been this way. I can't stand it anymore. Has anyone had this problem and then rooted and it fixed the problem? If so, do you need to flash a whole new ROM after rooting to fix the issue or is there some other "patch" or fix that can be applied to the stock ROM? Thanks!
- 11-20-2012, 03:04 PM #2
Re: will rooting help or fix GPS issue?
Are you Resistance or Enlightened? :-)
(Sorry, I don't have an answer about the GPS question.) - 11-20-2012, 03:13 PM #3
- 11-20-2012, 04:47 PM #4
- 11-20-2012, 11:12 PM #5
does OTA fix GPS issues? (or copy/paste issue?)
By Funkpod in forum Verizon Galaxy S3Replies: 29Last Post: 12-01-2012, 08:08 PM -
Anything that can fix GPS issue besides reatrting phone?
By 6tr6tr in forum Sprint Nexus S 4GReplies: 8Last Post: 02-29-2012, 10:38 PM -
Does rooting and ROMming fix GPS issues?
By Ticojpunk in forum Motorola Triumph on Virgin MobileReplies: 6Last Post: 11-14-2011, 03:31 AM -
will rooting help with weak signal
By evoldroid in forum Sprint Nexus S 4G Rooting, ROMs, and HacksReplies: 1Last Post: 07-19-2011, 07:24 PM -
Help with LG Optimus S! Hate the phone will rooting help?
By vkettell in forum LG Optimus SReplies: 7Last Post: 04-05-2011, 08:38 PM
Reply
