Results 1 to 3 of 3
    Default [HELP] Stuck on modem.bin ! Please help !
    Hello ,
    first im so sorry for my bad english language, i hope you are understand ,
    and..
    i have problem installing my epich touch 4G
    i dont know why i keep getting stuck on modem.bin on odin PC
    i try many firmware, and stock firmware to, and keep give me stuck on modem.bin
    i try download on xdawiki, on sammobile latest firmware, stock firmware and give me stuck again on modem.bin
    you will see stop icon left behind the battery indicator
    any advice?
    thank you very much..
  2. #2
    Default Re: [HELP] Stuck on modem.bin ! Please help !
    im on the same boat only it displays firmware upgrade encountered an issue please select recovery mode in kies & try again but wean connected to kies it only shows A spinning ring and never loads wean i try to flash anything it always get stuck on modem.bin
  3. #3
    I would say there is a problem in the line of code for the kernel. First question: Did you guys download a kernel for the Epic 4G Touch (E4GT)? If you didn't or are unsure, find one that is or go back to a base build that works. Just because it is a kernel for the S2, doesn't mean it is for the E4GT. Second, what version of ODIN are you using? I think the best version right now is 3.04, and some builds prefer one version to another.
    If you are absolutely sure you downloaded the right files, install an earlier build on ODIN, delete and redownload the file and try again.
  1. My droid 2 is stuck on moto M ahh :((((( help please
    By stevomesseduphisdroid in forum Motorola Droid 2
    Last Post: 02-29-2012, 01:25 AM
  2. Replies: 3
    Last Post: 12-15-2011, 03:41 PM
  3. Still unable to see device on my PC - Please HELP!
    By ochness in forum Verizon Fascinate
    Last Post: 04-01-2011, 10:02 AM
  4. Captivate Turns Off on its own, PLEASE HELP!
    By Musicmasta in forum AT&T Captivate
    Last Post: 01-03-2011, 02:48 PM
  5. Screen Locks to quick on HTC HERO... please help
    By SUP3RSTAN in forum HTC Hero
    Last Post: 11-21-2009, 11:46 AM
