Page 1 of 3 123 LastLast
Results 1 to 25 of 61
Like Tree5Likes
    Jason Lippe's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Massive Battery Drain on Samsung Galaxy S2 with JellyBean GB27
    I'm searching for anyone who recently installed JellyBean on their Samsung GalaxyS2 4G Epic. Just did the update today because we were having really bad battery performance with the phone with IceCream installed. Went to the Sprint store and they said the battery is fine (and of course had no other recommendations other than buy a new phone). But they did say that the JellyBean update would definitely help. So we did that.
    Have a Model SPH-D710 and are now on Version GB27 (4.1.2). Today the battery was drained in less than four hours. Even with Power Saving on, the Screen is averaging about 50% of the battery with the Android OS in second place taking up 11%.
    If anyone out there has had similar issues and has recommendations on how to best solve for it, I would appreciate any advice you have. Thanks.
  2. #2
    rraman3110's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock Rooted FK09 4.1.2
    Default Re: Massive Battery Drain on Samsung Galaxy S2 with JellyBean GB27
    Sometimes when new updates are installed on your device especially huge updates like upgrading OS versions will sometimes have some quirks. Your best bet is to do a couple of power drains. Meaning let the phone perform as expected and let it die. Then charge it completely while it is dead. The next time you use the phone you should see some improvements. Last ditch effort would be to get an OEM battery or re installing the update once again.
  3. #3
    Hawaiian_Geek's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Jelly Bean
    I've had Sprint store give me brand new free batteries for my SG2. They should have offered you a brand new battery. Yup, after a major update sometimes the phone takes a few power down cycles to happen then battery life is better. Also if your wallpaper is colorful it could take up power resources and if you have apps running in the background. I read somewhere using a wallpaper with not many colors helps battery life. Thus using a wallpaper with black color in it helps. I have tested using a wallpaper that is colorful and my battery tended to drain a lot faster compared to using a wallpaper with black/darker colors. That's just my own conclusion!
  4. #4
    13curly's Avatar
    Posts
    Global Posts
    81 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Also, if you're in an area that does not have WiMAX you might want to try turning off the Sprint Connections Optimizer. I found it was a huge drain on my battery.
    To turn it off, go to settings, select More Settings, Mobile Networks, Connections Optimizer, uncheck the box.
  5. #5
    Jeremy Ruzanski's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I get bread drain when I have crappy signal... some areas I can't get one 3g bar... and down goes battery quickly... very poor antenna in this phone... my wife has a photon... always much better reception than me.
    Sent from my SPH-D710 using Android Central Forums
    redhdgirl417 likes this.
  6. #6
    BBurg_16827's Avatar
    Posts
    Global Posts
    72 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Along with the massive battery drain, I find my phone giving me very poor signals most of the time now. Not sure if this is a known issue in the Philadelphia area or as a whole.
  7. #7
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yeah recently I've been getting worse signal, Dallas / Fort Worth
  8. #8
    UmbertoD's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hello,
    The main cause of battery drain in Jelly bean is the new 'Google Now'.
    Turn it off.You will find a on/off slider in settings.
    Also,enable all the four options under 'Power Saving' before enabling it.
    Thirdly,install the app 'PowerMax' from Play Store and activate it.Its darned good in saving battery consumption.
    I have a Galaxy Note which started having massive consumption of battery (draining in under 5 hours) since I updated to Jellybean.
    After the above steps,its back to 8-8.5 hours -what I used to get on ICS.
    Hope this helps.
    gb5766 and paulhead like this.
  9. #9
    Chuck Shine's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Where in Settings is the on/off slider to turn off Google Now?
  10. #10
    sblair1269's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    you have to go in to Google, then the settings there is where you can turn it off.
  11. #11
    Stardove Moon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by 13curly View Post
    I kept having Sprint ID cannot connect, but yet it cannot be uninstalled (another issue). Calling Sprint I was told to do the above. First I had to "allow" before I could get the the check mark to uncheck. Next every time I reboot (turn off and turn back on) the phone the check mark will reappear, so I have to go back and allow then uncheck. What a pain. It hasn't helped all the much with the battery drain, but at least it stops the Sprint ID from searching.
  12. #12
    dm3ready's Avatar
    Posts
    Global Posts
    449 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Chuck Shine View Post
    Open Google Now > Click Menu and select Settings > Click Google Now > On top right you will have the option to turn off Google Now.
    paulhead likes this.
  13. #13
    anozir's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm having the same problem with battery drain on display. ~60% of the battery drain is from the display and it discharges relatively quickly. ~20mins of usage knocks my battery from 100% to 60%. Anyone know why or have a solution?
  14. #14
    dm3ready's Avatar
    Posts
    Global Posts
    449 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by anozir View Post
    Have you reviewed and implemented tips and recommendation on this thread? If so, which ones?
  15. #15
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Jelly Bean
    Quote Originally Posted by dm3ready View Post
    I don't even see the Google Now in my APPS.....is it hidden somewhere or am I blind.....Would appreciate any assistance with this....detail info on steps to get to Google now will be appreciated! Thanks in advance!
    Edit: Never mind I found it....now gotta see if this off setting will not make battery drain...
  16. #16
    anozir's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sprint Connections Optimizer is off, Google Now is disabled and I've done a factory reset. Light use of the phone (57 minutes of display use) and the battery is down to 24%.
  17. #17
    paulhead's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How old is your battery? Do some searches on these threads you'll find the answer. I don't use facebook on my phone any more. After my reset I've installed very few apps, not even FB and I'm getting avg 12 hrs, sometimes less with heavier use. But if I leave it alone It'll only lose a few %'s after a few hours. But after a year I got a new battery too.
  18. #18
    jmettee's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have a fairly new battery & seeing much faster battery drain than when on ICS. Screen always shows huge drain, but standby lasts a long time. In fact, when I'm using mine while plugged in, the phone actually DROPS in power instead of charging. Never used to do that before on ICS.
  19. #19
    Rajesh Roy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had the same issue and resolved by resetting device along with formatting inbuilt device memory and attached SD card. formatting a device will clear old junks. Please take backup of your important stuffs before formatting your device.
    Golfdriver97 likes this.
  20. #20
    jmettee's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I can confirm that factory reset took care of my issue. Phone doesn't drain as fast & now actually charges while using it.
    Thank!
  21. #21
    Mike Crowley1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had the same problem, lucky to get 3 hours after the 4.1.2 update. Called Boost, and was told to do the reset option on the phone, of course you will loose all info on the phone, so back up with google and it will be beter after, but now the phone locks up at idle sometimes, and I never know when until I go to use it! It turned a great phone into a ZTE warp! I do hope they come up with a patch fix! I even asked if there was a way to go back to ICS, but no there isnt. The other problem I have is screencap is no longer working... I loved that option.
  22. #22
    Riboflavin's Avatar
    Posts
    Global Posts
    268 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I was just browsing the web on my phone. Battery was at like 41%. Then phone lost signal and straight up died on me. Tried to turn it back on, but battery was at 0%. Got into work and plugged it in and turned it on. Battery was at 51%.
    Third time my battery has done something weird like this.
  23. #23
    are_gie's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Absolutely same problem. Vodafone sent me a new phone with their install of JellyBean, which had the same problem. Major drain in idle (but at least it didn't get hot!) They have now given me an older IceCreamSandwich version with updates turned off.
    Wow I'm please to have a rest for battling with Kies (which must be the worst corporate commercial software ever written) and reinstalling apps. Maybe a Sony Xperia next time.
  24. #24
    takehiro12's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yup, Factory Reset fixed my problem too. I was primarily having a reset issue, but I was also seeing horrible battery drain and my phone was warm all the time. Turning off Google Now and using power saving had absolutely no effect. I backed up my apps and data then booted to recovery and reset. It stopped restarting and battery life is the best I've seen over the life of the phone!
  25. #25
    paulhead's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think I got my phone dialed in pretty well. Did most of the stuff stated above, got rid of some apps too. I don't use the phone for more than calls, texting and emails too. I think the phone does a good job of monitoring itself without the help of apps. I tried juice defender and power max and they seemed to cause more problems than fix. Got rid of Facebook and Photobucket also. Am using widget locker, Tesla unread plugin, circle battery widget, ClockQ, Quickshortcut maker and few others (Pandora etc) and power is just fine. Unplugged the phone at 4pm yesterday, light to medium use til bed, left it unplugged, light to medium use this morning and at 19 hours it was at 42% . I'm digging it.
  1. "Facebook authentication failed" on Samsung Galaxy s2
    By katie_dee in forum Android Apps
    Last Post: 08-26-2013, 08:21 PM
  2. ICS Problems using foxfi on samsung galaxy s2
    By bro.doug in forum Samsung Galaxy S II
    Last Post: 07-02-2012, 12:01 AM
  3. Facebook battery drain on unlocked Galaxy Nexus
    By LCW in forum Google / Samsung Galaxy Nexus
    Last Post: 05-01-2012, 10:44 AM
  4. Amazing Deal on Samsung Galaxy S2 - Costco Canada
    By GetHyper in forum Bell Galaxy S II
    Last Post: 11-30-2011, 11:13 PM
  5. ATT Samsung Galaxy S2 with case and headphones
    By MrszBerry in forum Marketplace Archive
    Last Post: 11-09-2011, 05:43 AM
