As it says...
Cause: ROM Flash failed half-way through and killed both partitions, now I'm stuck with download mode, and it won't connect even after properly re-installing drivers
Problem 1. Only Download mode available
Problem 2. Computer (or phone) refuses to make the connection to reflash again.
I've exhausted the only options I knew.
Have about two months of experience with having a rooted phone. Soft bricked it a few times before this but this one looks to me to be a hardware manual-reprogram that I need to do. The connection issue, if it's the phone, would require some sort of coding software or device to manually execute code through a keyed connection, like for universal remotes... but I'm not sure if they exist for microusb connections running Android at the other end...
