Results 1 to 8 of 8
    Default Using USB to car audio player (please read before replying)
    I know I will get a ton of answers that will look like this.
    • Why not just use the 3.5 jack?
    • Why not use bluetooth?
    • Use an external SD and the SGS3 Easy UMS
    That is just a few I know will be tossed out there, so please let me explain and reply if you can with any help, it will be greatly appreciated.
    I was an Iphone user for 2 years and the idea of using the USB port on my Pioneer radio worked perfect for me, because of my drives back and forth to campus everyday. It charges my phone, gave me control of the radio controls and vice versa. For me it is the best case scenario and I have heard of people being able to pull it off with an app call AAlinq and Grom cable. I am wondering if anyone from this board can come up with any ideas or has any thought on a fix. I have also seen a trick that involves using the external SD and copy/paste from internal and it works. But I am looking for a way to use the internal SD, the supplied usb cable (if it requires an additional cable that is fine also) to install on my Pioneer car radio. I basically am looking for an Iphone mimic without dragging a ton of hardware into my vehicle every time I leave for school.
    Once again I apologize for the stipulations I wrote above, I am not trying to troll you guys or be an ***, I have read to many threads about this topic that get off basis and it is not very helpful.
    Sprint Galaxy S3 - SPH-L710
    JellyBomb ver. 8.0.0
    www.djdig.com
    Thanked by:
  2. Thread Author  Thread Author    #2
    Default Re: Using USB to car audio player (please read before replying)
    I know the answer is probably no way it can be done due to the internal card being an MTP configuration and there is no way (for now) to have one location on that drive partitioned to UMS mass storage because of the way MTP combines everything together on the internal card. I do have a 32gb Class 10 Scandisk sd coming in this week and will use the alternate method from the xda site. I am just hoping that there is a slim chance some developer/user might see this and give an alternate way of doing it.
    Thank you,
    www.djdig.com
    Okay I read through all the scripts and the Easy UMS thread and the only thing that has worked for me is making a script that says. Now it changes over to UMS but shortly after the phone freezes and I have to reboot and once I do that it is no longer in UMS mode, anyone have any ideas on where to go from here? Not using any roms, phone is rooted, busybox, all the usual suspects installed. No version of easy UMS worked, it was always looking for s3c-usbgadget or /lun that I did not have.
    echo 0 > /sys/devices/virtual/android_usb/android0/enable
    umount /mnt/extSdCard/
    echo "mass_storage,adb" > /sys/class/android_usb/android0/functions
    echo "/dev/block/vold/179:97" > /sys/devices/virtual/android_usb/android0/f_mass_storage/lun/file
    echo 1 > /sys/devices/virtual/android_usb/android0/enable
    www.djdig.com
  4. #4
    The Google Play app named SoundAbout has a media audio setting for Aux Digital. If you car supports USB audio, it should work.
    I want it to act as a usb mass storage device so my receiver will pick it up and I can just use the external SD as USB
    www.djdig.com
    Just posting my fix to my previous post after playing around with it for so long.
    Sprint Galaxy S3 - SPH-L710 (rooted, stock rom)
    Android Version: 4.1.1
    Used Rom Toolbox and loaded these 2 scripts.
    Mass Storage.sh
    MTP.sh
    echo "" > /sys/devices/virtual/android_usb/android0/f_mass_storage/lun/file
    echo "mtp,acm,adb" > /sys/class/android_usb/android0/functions
    vold
    www.djdig.com
  7. #7
    sircody's Avatar
    Posts
    Global Posts
    107 Global Posts
    Quote Originally Posted by djdig View Post
    That's pretty much the norm for Infotainment systems in cars today if usb from device is used as player or are talking something else?
  8. #8
    I have the same problem, an iPhone user for years I liked that I could just plug it into the car, charge it and listen to all my music at the same time - without having to perform lots of button pressing first. So if I get this right, you have this problem solved? As a total newbie to Android I would appreciate some help with doing the same.
    Thanks,
    G
  1. How do I listen to music over USB to car stereo?
    By ztmike in forum Verizon Galaxy Nexus
    Last Post: 05-01-2013, 02:57 PM
  2. Replies: 3
    Last Post: 11-28-2012, 02:10 PM
  3. Replies: 1
    Last Post: 09-15-2012, 09:15 PM
  4. 1 full day and I want to return this phone...please read
    By jeffreynothing43 in forum Sprint Galaxy Nexus
    Last Post: 06-30-2012, 11:53 PM
  5. Droid USB to car stereo
    By PRNmeds in forum Motorola Droid
    Last Post: 07-01-2010, 08:50 AM
