1. Anglingaddict's Avatar
    I have a sg3 with MOAR rom. Having an issue with the battery. Dying quickly but after I plug it in the battery always says 51%. Then it dies again when the meter is close to 30 to 35%. Sometimes while calling someone or trying to take a pic it just blacks out and turns off. Any ideas?Click image for larger version.
    08-17-2014 10:18 PM
  2. wizzrah's Avatar
    Hello.
    It must be because you have too much ROM. (moar... get it? bah dum tsk).
    Anyways, if the battery meter is stuck, try rebooting the phone to see if it corrects it and it tells you how much battery you really have.
    Some things I recommend trying:
    1. Wipe cache in recovery.
    2. Try flashing a different ROM.
    3. Report problems to the developer/developing team.
    08-17-2014 10:50 PM
  3. Anglingaddict's Avatar
    Hello.
    Did a battery pull left it out for an hour . Has been fine flashed this rom back in October but just started having issues these past couple weeks. Will try the cache wipe
    08-17-2014 11:06 PM
  4. wizzrah's Avatar
    Let me know if the problems persist. I'll be happy to help.
    08-18-2014 12:50 AM
  5. Anglingaddict's Avatar
    Ok did the wipe and re flashed rom. Let the battery drain from 90 to 1% before it turned off. Plugged it in and restarted battery back up to 42% literally after plugging in and waiting for it to turn back on. Any ideas?
    08-18-2014 08:39 AM
  6. wizzrah's Avatar
    Wait, so it won't turn on?
    08-19-2014 11:04 PM
  1. serious battery problem on S3
    By Bphob in forum Ask a Question
    Last Post: 08-18-2014, 02:26 AM
  2. samsung galaxy s5 on at&t /visx custom rom question
    By Blake Decker1 in forum Samsung Galaxy S5
    Last Post: 08-17-2014, 06:26 PM
  3. Razr black screen issue
    Last Post: 08-17-2014, 03:32 PM
  4. Samsung s4 towel root installing custom rom.
    By Omar Nadeem in forum Ask a Question
    Last Post: 08-17-2014, 02:30 PM
