Page 2 of 5 FirstFirst 12345 LastLast
Results 26 to 50 of 108
Like Tree34Likes
  1. Thread Author  Thread Author    #26
    hiero's Avatar
    Posts
    Global Posts
    146 Global Posts
    Exclamation Re: help needed, replaced build.prop and phone won't start up now
    Just found this!! Someone please tell me this will fix things?? And how do I use the file? (am downloading it now)
  2. #27
    Paul627g's Avatar
    Posts
    Global Posts
    13,749 Global Posts
    ROM
    Milestone 1/Lean Kernel
    Default Re: help needed, replaced build.prop and phone won't start up now
    Quote Originally Posted by hiero View Post
    This is of no use unless your a kernel or ROM developer. This is the source code which is required by law for them to release as an OEM, observing the GPL rules.
    There is nothing here for me or you to flash.
    Again guys, as you continue on your journey down the Android path remember to keep passing the knowledge along in which you have gained by this... ALWAYS fully understand what it is you are doing and NEVER skip the Nandroid Backup, especially on a brand new released device.. Sucks to know that the 5 minutes it would of taken to make the Nandroid Backup could of saved you from all this mess
    Thanked by 3:
  3. #28
    Uncle Louie's Avatar
    Posts
    ROM
    SwampMonster V1.0!!!!!
    Default
    Thanks for looking out UL! unfortunately, that only fixes the bootloader it looks like (I hope I'm getting the terminology correct here). I had found that link earlier and actually went ahead and tried it, unfortunately, it helps you get the phone to boot, but not fix the ROM problems that I incurred by trying to mess with build.prop (boy am I learning some lessons fast).
    If you can nandroid for me tomorrow that would be fantastic UL! Please keep me updated and for the rest of the forum, I would be happy to provide that stock backup to anyone who needs it (with the ok from the original owner of course).
    Sure thing... Give me a little time, but it shouldn't be a problem.
    Thanked by 2:
    dmmarckhiero
    hiero and dmmarck like this.
  4. Thread Author  Thread Author    #29
    hiero's Avatar
    Posts
    Global Posts
    146 Global Posts
    Quote Originally Posted by Paul627g View Post
    ah well, worth a glimmer of hope, UL to the rescue now!
    dmmarck likes this.
  5. #30
    Posts
    ROM
    Default
    Lol... I couldn't wait, so I did the Nandroid already. So now the question becomes.... How do I get it to hiero?
    Thanked by:
    hiero
  6. Thread Author  Thread Author    #31
    hiero's Avatar
    Posts
    Global Posts
    146 Global Posts
    Quote Originally Posted by Uncle Louie View Post
    PMimg now!
  7. #32
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Do you have Dropbox? You should be able to upload it to there and throw him a link. It'll be big. It should be a folder within your SDcard...probably clockworkmod is the name (or something like that or ROM Manager). Find the folder with the name it saved as (usually the date/time), and that's what you'll want.
    You can longpress on that with something like Root Explorer to share it, or you can plug your phone in and simply copy and paste that folder from your phone's drive to your computer then upload from there.
    Thanked by:
    Uncle Louie likes this.
  8. #33
    Definitely a learn from my mistake moment... You know I will be taking a backup the first second I get my firmware backup and running!
    Thanked by:
    hiero
    dmmarck likes this.
  9. Thread Author  Thread Author    #34
    hiero's Avatar
    Posts
    Global Posts
    146 Global Posts
    Quote Originally Posted by dmmarck View Post
    Yes! I just sent a PM with dropbox, yousendit, etc, depends on the size of the file of course, what should we expect as far as size ballpark?
  10. #35
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    They can get big. I've had some as little at 500 megs and some as big as 1.3 gigs, depending on apps and such of course.
    Is there a size limit for uploading with dropbox? I've never gotten crazy with it so i have no idea. He could also zip it up, but then you MUST unzip it b/c it needs to be in its "folder" form for you to restore.
    Then you're going to have to make sure that you have your backups folder (which you undoubtedly do you if you have already made on). Slide that sucker in there, and don't rename it. People like doing that, but honestly, at this point, we're taking the path of least resistance and least risk lol
    Thanked by:
    hiero
  11. Thread Author  Thread Author    #36
    hiero's Avatar
    Posts
    Global Posts
    146 Global Posts
    wow, yeah, dropbox's web interface has a limit of 300MB, but if you use the desktop version the only limit is how much space you have available (i.e. if your max storage is 2GB, then you could upload a 2GB file.
  12. #37
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Well then let's hope Uncle Louie is a Dropbox application enthusiast .
    Does Google Drive have an upload limit?
  13. #38
    If there is anything I can do to help let me know. I have Google Drive, SkyDrive, Dropbox, and potential an FTP site we could through it up on. Also mediafire may be an option....
    Thanked by:
    dmmarck likes this.
  14. #39
    Paul627g's Avatar
    Posts
    Global Posts
    13,749 Global Posts
    ROM
    Default
    how big is the nandroid backup?
    Worst case take 7 zip and just Zip/Compress the file... That should compress it with 7zip's stock settings by at least a good 60-75% of original size...
    That would then make the upload and download easier for both of you... Then when he downloads the file, unzip/extract it before placing it in his clockwork/backup/ directory to restore in CWM.
    I've had to do this many times when uploading an Odin tar file (Which is what we use on Samsung devices...) they are normally about 200+ megabytes for the factory restore image so it compresses it to a nice 150-160 megabytes....
    Mediafire & Mediashare both have 200 megabyte file size limits along with many other free file hosting services.. So the "zipping" option is a nice workaround to fit those bigger files Yes this isn't my first rodeo .... LOL
    Sent from my Nexus S 4G using Android Central Forums
    Thanked by:
  15. #40
    Posts
    ROM
    Lol...between the EVO LTE I bought (and returned) and the GS3, I have almost 80gb.
    I think we're covered.
  16. #41
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Superb! Did you find the folder? Like Paul said, you can zip it up and upload it or upload it right from Root Explorer/similar file explorer apps.
  17. #42
    Posts
    ROM
    Yep...uploading it now. 1.08gb.
    Looks like it might take a bit.
    Thanked by:
    hiero
  18. #43
    Paul627g's Avatar
    Posts
    Global Posts
    13,749 Global Posts
    ROM
    Good luck guys... We will hang by and check in from time to time....
    Thanked by 2:
    hiero likes this.
  19. #44
    Posts
    ROM
    Dang it...didn't read your post before I started uploading.
    I will definitely do that in the future, though!
    dmmarck likes this.
  20. #45
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Superb.
    hiero/zharris - from your end, do you know what you have to do?
    1. Download from the Dropbox link
    2. If zipped, unzip it.
    3. Place that file on your SDcard in the backups folder (which itself is within the clockwordmod folder). I believe this folder should be, in theory, "/sdcard/clockworkmod/backups" or something to that effect.
    4. Boot into Recovery (ClockworkMod, unless Zeus hates you and your recovery is gone).
    5. Go to restore and choose that folder.
    6. Wait, wait, wait. Pray a bit if that's your thing, have a cigarette or a drink or something.
    7. Hopefully reboot into awesomeness.
    Thanked by:
  21. #46
    If that's the case then I will probably download it first thing tomorrow morning if that is OK with you.
  22. #47
    Superb.
    [INFO]
    [/INFO]
    Question: Apparently the only CWM for the galaxy s3 right now isn't the touch version. Therefore you can access your external SD card from recovery. If we can't get to our external SD is there another way we can do this? Via adb shell or Odin? Or do we have to just wait for CWM touch to be available for the s3?
  23. #48
    Posts
    ROM
    Quote Originally Posted by zharris24 View Post
    That will work...it has about another 50 minutes on the upload anyway. Shoot me an email address when you get a chance so that I can send you a Dropbox link.
  24. #49
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Odin is not my ball game, Paul's much better with that. You CAN adb push it though, at least in theory.
    But, if there's an external SDcard (and there is, right? Sorry it's late lol) you can always pop that in another device and load it through there. I can't tell you how many phones my DINC unbricked by doing that, but it's probably near the teens lol
  25. #50
    Maybe I'm missing something, but I don't think you NEED the touch version. The difference is that you'll have to navigate CWM with your volume and power buttons (up/down to move through menus, power to select the highlighted option).
    Oh, and as dmmark suggested, I too would load the nandroid right onto the SD card directly.
