Page 3 of 5 FirstFirst 12345 LastLast
Results 51 to 75 of 119
Like Tree35Likes
  1. #51
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Default Re: help needed, replaced build.prop and phone won't start up now
    Quote Originally Posted by PookiePrancer View Post
    Maybe I'm missing something, but I don't think you NEED the touch version. The difference is that you'll have to navigate CWM with your volume and power buttons (up/down to move through menus, power to select the highlighted option).
    Correct. However, the non-touch version is a massive pain in the neck, or at least it was on my phone.
    Also, when you get a chance--flash TWRP. It's awesome .
    But...I should not be filling your minds with such temptation before the phone is back and alive, so ignore that for now!
  2. #52
    Oh, and as dmmark suggested, I too would load the nandroid right onto the SD card directly.
    Thanks for the replies. However my issue wouldn't be getting the file onto the SD card itself. The issue is getting the galaxy s3 CWM to read the SD card once it is loaded onto the s3. The difference with the touch version is that it gives the option of reading the external or internal SD cards where the regular cwm only reads the internal SD card. I hope I am wrong about this but wanted to see if anyone else had run into this.
    Thanked by:
    hiero
  3. Thread Author  Thread Author    #53
    hiero's Avatar
    Posts
    Global Posts
    146 Global Posts
    Quote Originally Posted by zharris24 View Post
    I see zharris's problem, looking at the CWM menu listing now:
    - reboot system now
    - install zip from sdcard
    +choose zip from sdcard (I don't see any external sd card in the file system, even after I mount the external card from 'mounts and storage')
    +apply /sdcard/update.zip
    +toggle signature verification
    +toggle script asserts
    +go back
    - wipe data/factory reset
    - wipe cache partition
    - backup and restore
    +backup
    +restore
    +advanced restore
    +go back
    - mounts and storage
    - advanced
  4. #54
    Paul627g's Avatar
    Posts
    Global Posts
    13,771 Global Posts
    ROM
    Milestone 1/Lean Kernel
    Default
    Sorry I can't be of much more help on the CWM guys. Not knowing what exactly the setup is for the SGSIII it's hard to say...
    TWRP recovery as dmmarck mentioned isn't even available yet for you guys but when it is, that is what I would switch to for your custom recovery.
    One option to move it into the internal storage is use the Mounts and Storage option in CWM. Then you can connect your device to your computer via USB and transfer the file to the internal storage or wherever your CWM directory is on the SGSIII.
    Sent from my Nexus S 4G using Android Central Forums
    Thanked by:
  5. #55
    Uncle Louie's Avatar
    Posts
    ROM
    SwampMonster V1.0!!!!!
    I pulled the backup that I made for you guys from my internal SD...that's where CWM had it stored by default. I restored my original from the same place, so assuming that you can access that, it should work.
    Thanked by:
    hiero
    hiero likes this.
  6. #56
    Posts
    ROM
    Oh, and if you didn't see the PM's, I sent you both the links. Have at it!
    Thanked by 2:
    dmmarckhiero
    hiero likes this.
  7. #57
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Default
    Quote Originally Posted by Uncle Louie View Post
    You are the man. Thanks for your help!
  8. #58
    Posts
    ROM
    Quote Originally Posted by dmmarck View Post
    Hey, thank you too; it was your idea to begin with! Thank you too, Paul!
    Thanked by:
  9. Thread Author  Thread Author    #59
    hiero's Avatar
    Posts
    Global Posts
    146 Global Posts
    downloading now! absolutely bow down to UL for this!!
    unfortunately, it seems that the USB driver is failing on my computer for some reason...
    I'm going to try to do a fresh install on my desktop and see if it will see the phone as a drive I can access....
  10. #60
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Default
    I believe Paul was in it first. Regardless, this is what the Android community and Android Central is all about.
  11. #61
    Paul627g's Avatar
    Posts
    Global Posts
    13,771 Global Posts
    ROM
    No thanks needed here.... Seeing these two get their phones back up and going again will be all the thanks I need.
    Thanks UL for providing the Nandroid... Great example of someone going out of their way to help another member
  12. #62
    Tkbredx's Avatar
    Posts
    Global Posts
    1,839 Global Posts
    ROM
    TeamSonicFreeGS3 v9.1
    Default
    It's official. I won't be rooting. I'm too scared lol. Chickening out. Lol. Goodluck to you heiro. And to those out there helping him, hats off to you my friends.
    Thanked by:
  13. #63
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Default
    Quote Originally Posted by Tkbredx View Post
    Don't panic; with due diligence and an ounce of courage your phone can be turned into a device so powerful it will create anti matter.
    Thanked by:
    Golfdriver97 likes this.
  14. #64
    Paul627g's Avatar
    Posts
    Global Posts
    13,771 Global Posts
    ROM
    Don't let this example here turn you away...
    1. They both had an easy, successful root & installation of CWM (ClockWorkMod) recovery.
    2. They both altered something in the file system which caused things to screw up. This is fine except....
    2a. They didn't make Nandroid Backup's before they attempted any changes. This would of given them both a "Get out of jail free card" to return back to their original setup before they made any alterations to their devices after achieving successful root/CWM.
    3. They also both did without the release of a "Restore or Return to Stock" option. This is a complete restore using Odin "same program you use to flash the custom recovery". The package will restore your device back to stock Android 4.0.4 & remove root & replace any custom recoveries with the stock OEM/Android recovery with no signs of being rooted.
    Sorry I don't mean to make examples of these two but it shows how a simple mistake of not making a Nandroid Backup and waiting to attempt anything without a Restore option got them in trouble. This is also the same reasons you don't see any custom ROMs popping out yet, the ROM devs don't want to start fooling around and end up in a situation where they need the Restore option that we currently don't have.
    Thanked by 2:
    hiero likes this.
  15. Thread Author  Thread Author    #65
    hiero's Avatar
    Posts
    Global Posts
    146 Global Posts
    so my phone will turn into Lord Nibbler?? sweet
    and Paul627g, if someone can learn from my mistakes I'm all for it!
  16. #66
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Default
    Quote Originally Posted by hiero View Post
    Well played
    Sent from my TARDIS
  17. #67
    cyberdalek's Avatar
    Posts
    Global Posts
    366 Global Posts
    ROM
    Affinity/Franco
    Default
    Sent from my TARDIS
    Love the new sig. All it took was half of the first season. :-)
    "There's always something to look at if you open your eyes."
    -The Doctor
    Thanked by:
  18. Thread Author  Thread Author    #68
    hiero's Avatar
    Posts
    Global Posts
    146 Global Posts
    OMG. It's done, I have recovered!!!!!
    OK, the process was WAY more painful than it should have been, but again, my fault.
    HUGE thank you to everyone on this thread who pitched in! With such a quick response too! AMAZINGLY responsive forum!
    And A HUGE THANK YOU TO UNCLE LOUIE.
    So I ended up figuring out that if you just turn the phone on normally and let it get past the 'Samsung Galaxy S3' screen to a blank screen, if you plug a USB cable in, it seems to actually connect to the computer. Unfortunately, it does NOT connect to the computer via normal windows USB connection and it does not show up as a drive.
    Fortunately, I downloaded and installed ADB and installed the platform tools to get ADB functions enabled (I also installed the google USB drivers, but unsure if that helped or not). Once I had that, I thought I would just try to connect the phone and try a adb push of Uncle Louie's recover folder. Sure enough, IT WORKED.
    Unfortunately, I uploaded it to the root instead of the proper /SDCARD/clockworkmod/backup folder! DOH. And yet again, unfortunately, I kept accidentally pushing the 'recover' button on the stupid CWM interface. What ended up happening? You can guess I hope, I RAN OUT OF SPACE. UGH.
    So eventually I figured I'd just push to one of the existing backup folders and have it replace the files there. That worked and then the CWM recovery went through perfectly!
    Now I'm back and setting up my phone again, but that's not so bad!
    It's late and if I'm forgetting anything, I'll come back tomorrow and update. zharris24, I'm here if you need help with the process!
    Thanked by 2:
    bu11etpr00f likes this.
  19. #69
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Default
    Quote Originally Posted by Xfanatic View Post
    -The Doctor
    I presume you are on g+? It's been quite a day lol.
    The best news all night! Good job!
    Sent from my TARDIS
  20. #70
    Posts
    ROM
    YAY! Glad it worked out for you!
    Thanked by:
    hiero
  21. #71
    Paul627g's Avatar
    Posts
    Global Posts
    13,771 Global Posts
    ROM
    Default
    Awesome! One down, one to go :-D
    Everyone involved did a great job.
    Thanked by:
    hiero
  22. #72
    Downloading UL's file. Thanks again UL, if it worked for Hiero, I am hoping the same goes for me! I figured CWM wouldn't read the external SD card and was afraid that adb shell was needed.... Hopefully I can get my phone recognized on my computer so I can get adb shell going... I have a feeling it's going to be a long day. In any manner, thanks to everyone for the help. UL I can't give you enough thanks!
    Thanked by:
    hiero likes this.
  23. #73
    Posts
    ROM
    Default
    Glad I could help out... Let us know how it goes!
  24. Thread Author  Thread Author    #74
    hiero's Avatar
    Posts
    Global Posts
    146 Global Posts
    Yes! Please do!
  25. #75
    Yes! Please do!
    So as of right now, I can't get CWM to read the backup file off of the external SD. So it looks like I am going to have to go the ADB route however, my phone freezes at the "Samsung Galaxy S3" screen and doesn't ever to go a blank screen where ADB can connect to it. Any thoughts? I have all Samsung drivers installed as well as Google's USB drivers, but still can't get adb shell to connect. I'll keep digging but any thoughts would be helpful.
