- 06-25-2012, 11:50 PM #101
- 06-26-2012, 12:41 AM #102
after reading this saga I was definitely shocked by a couple things: 1) all of this was completed successfully in 1 day and 2) that I was still reading and not turning off my tv after some drama. I was not surprised by the support (as quick as it was) of the Community. Really great outcome. Congrats to all!
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2 - 06-26-2012, 08:45 AM #103
Re: help needed, replaced build.prop and phone won't start up now
Good job everyone... Man this was quite a quick crash course in learning the ins and outs of CWM/ADB/Nandroids/Drivers..
Fun isn't it? LOL.... You guys got thru this you can do anything now..
Remember those Nandroids guys... I suggest making one and throwing an extra copy on your computer for safe keeping.
:: Getting Started with Android :: Forum Rules :: General Help and How To ::
» » » The All New Android Central App « « «
- 07-16-2012, 06:21 PM #104
- 07-16-2012, 06:31 PM #105
Can you still get into Clockwork recovery?
Sent from my SPH-L710 using Android Central Forums - 07-16-2012, 06:54 PM #106
Re: [SOLVED] help needed, replaced build.prop & phone won't start
yea I can still get into CWM and Odin mode. Just can't install cm9 Rom or install the update SPH_LF9_to_LG2 that I used to update the stock firmware. I used team epic root from recovery in CWM to gain root access. Problem is the beats audio installer app updated today and I tried installing it and it seemed to work, but when I went to restart using the phones restart option the phone froze for five minutes till I pulled the batt. Started it backup and every time it would seem to stall on the Samsung logo boot animations after the SGS3 screen and the sprint screen. CWM failed to let me flash the stock Rom update zip from my phone so I tried wiping data and then formated system. Now can't get past the galaxy s3 screen just sits on it. I tried using Odin to flash the 10mb sprint stock tar and didn't seem to make a difference.
sorry for long explanation. Tried to be thorough. - 07-18-2012, 03:43 PM
Thread Author #107
any luck anoosh?
- 04-12-2013, 03:09 AM #108
- 05-19-2013, 11:32 AM #109
- 05-19-2013, 03:12 PM #110
Re: [SOLVED] help needed, replaced build.prop & phone won't start up
Will it boot into recovery mode? (I don't know how to do this on the ZTE, you'll have to search for that information.) If you can boot into recovery, choose Factory Reset and you should be able to recover.
PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
If I've helped you, please press the Thanks button.
Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3 - 05-19-2013, 03:45 PM #111
I in recovery wipe data and cache but dont help me. I cant still start phone...
How can fix? But i have only android recovery, i havent CWM recovery
. Say me can i fix or no? I have new phone maybe 14 days ..
- 05-19-2013, 04:23 PM #112When I let go of what I am; I become what I might be. - Lao Tzu
Current devices: Galaxy S3, Galaxy Tab 2 7.0
Retired Devices: Galaxy S2 (Epic 4G Touch) - 05-19-2013, 04:41 PM #113
Not i havent friend with ZTE
. But i have idea. I can copy on sd card all with my 2 phone and after give sd card back to my ZTE grand x and after flash, but i havent CWM recovery, i got only android recovery mod (i dont know name for this), when i flashing rom last week with this mode dont work (rom not flashed).
Help this somehow? I havent CWM recovery, so i cant back up or restore i have only android recovery mode (i dont know name for this)
Is there any way to fix? Or not? - 05-19-2013, 09:31 PM #114
Even with the stock recovery, there should be a factory reset option, which should bring back the original build.prop.
Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3 - 05-19-2013, 10:38 PM #115When I let go of what I am; I become what I might be. - Lao Tzu
Retired Devices: Galaxy S2 (Epic 4G Touch) - 05-20-2013, 01:14 AM #116
Not i dont tried a factory reset. How can factory reset, when cant start phone???
Or how can recovery stock rom? When i havent cwm recovery? I have only android recovery mode, but here is not back up or restore. Here can only wipe data and cache and install zip from sd card, but when i install last week rom (last week my mobilework normal), so installing failed, but i can try it again now. - 05-20-2013, 07:52 AM #117
Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3 - 05-20-2013, 08:44 AM #118
For recovery need USB method: Connect to pc software and this can do only when phone start i think
So now i cant do nothing?
I 1x do CWM recovery, but after cant go to recovery. Here is change i have recovery, but i dont know how go to recovery.
- 05-20-2013, 09:28 AM #119
I'm sorry, I don't know how to start recovery on the ZTE. Every phone manufacturer seems to have it's own method.
Reply
