Results 1 to 2 of 2
    _MARS1010's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Meaning of the LED notification lights
    Ok when it comes to led notifiers I'm pretty much used to BlackBerry and it's completely different on the SGS3 the yellow light is on continuously and it doesn't blink when ever I do get notifications so yea...looked on YouTube and still wasn't able to find anything...can you program colors on the stock app?
  2. #2
    Gator352's Avatar
    Posts
    Global Posts
    3,838 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Meaning of the LED notification lights
    um, sounds like you need to take a trip to sprint or wherever you bought it cause that doesn't sound normal.
    But if your looking for some sort of custom lighting for your LED, the only real or best option is this:
    http://www.androidcentral.com/light-...-bean-included
