Results 1 to 17 of 17
    Default Application monitor widget problem...
    Ever since the new update, I cannot seem to get the app monitor widget to work. If I add the widget, it does nothing even when tapping it. If I remove the widget, then every time I start my phone ( restart or cold boot), it says..."problem with application monitor and was not started". Has anyone had a problem?
  2. #2
    Skunkape60's Avatar
    Retired Ambassador
    Posts
    Default
    I looked everywhere and don't even know what your talking about. What is the application monitor widget? I am completely clueless to what you are talking about. Is this a 3rd part app/widget. Because it isn't on my phone.
    _______________
    Just Flash It !!!
    http://forums.androidcentral.com/signaturepics/sigpic70132_2.gif
    Default Re: Application monitor widget problem...
    No it's stock. Under widgets, it's "application monitor" 2x1. Looks exactly like the "assistive light" widget and "alarm" widget.
    Its the widget that tells you whats running and able to kill the app. It was also on the S2.
    I think I'm being an *****. I think those might be part of HD widgets. I've had HD widgets since it came out and always install it before just about anything else with the phone. I'm gonna delete HD widgets and find out.If this is this case.....I'm going to change the thread name to "beat up on Gator352 day!"
  5. #5
    no its stock. it doesnt work on mines either after the update. it doesnt do anything anymore.
    Thanked by:
  6. #6
    Quote Originally Posted by Gator352 View Post
    I had the same problem as well after the update. I don't use the program so I just uninstalled it. I'm not rooted or anything so I doubt it's a conflict with an app.
    Thanked by:
  7. #7
    you must have downloaded it from the Samsung Apps program, because it's not stock on the S3... Anyway, no it's not working, Samsung will update it soon... You'll be able to find it via the Samsung Apps library once updated...
  8. #8
    illiniah's Avatar
    Posts
    Global Posts
    27 Global Posts
    It is a stock "Widget" with the S3 (another poster already explained where to find it if you are not familiar with Android or Samsung phones - you do not need to download it from Samsung.
    I had the same problem with the widget after the update. I just deleted the widget and reinstalled it - so far so good.
    I suggest that the "experts" do some research before bashing posters.
  9. #9
    mobdad's Avatar
    Posts
    ROM
    LIH Jelly Bean Leak
    Just to clarify, this widget is not in my current widgets either (I have upgraded manually to the LG8 upgrade) but I found it in the Samsung Apps application.
  10. Thread Author  Thread Author    #10
    I'm wondering if the first few batches shipped had it pre-installed but the later batches was removed. Cause I distinctively remember adding and removing widgets before I installed any apps and it was one I placed on an empty screen. Plus, I uninstalled HD widgets and they are still there.
    I also know you can get it from the samsung app market.
  11. #11
    i remember getting it from the samsung app store. i un-installed it, after it stop working, but now it wont even let you re-install it from there.
    guess the update broke it.
  12. #12
    Skunkape60's Avatar
    Retired Ambassador
    Posts
    Default
    Quote Originally Posted by illiniEE View Post
    I was not bashing anyone. And no it was not loaded on my stock phone. I haven't removed a single app or widget from this phone since the day I got it. It wasn't and still isn't on my phone.
    Thanked by 2:
  13. #13
    mobdad's Avatar
    Posts
    ROM
    LIH Jelly Bean Leak
    I agree with "Skunk". There was no bashing in his post. He is one of the most helpful and selfless posters on the forum. We are lucky to have this guy.
    Thanked by 2:
  14. Thread Author  Thread Author    #14
    Default
    I agree. Thanks for everyone's help but I got it working. I uninstalled then Samsung's application store let me reinstall it.
  15. #15
    Default
    It came from the Samsung App store. I had to uninstall and then reinstall after the latest update. Works fine now.
    There's an app that was pre-installed called More Services. It takes you to Samsung's page in the Samsung App store. Here you'll find the photo editor app and a super nice video editor app as well.
    Samsung Galaxy S3 - Samsung Epic 4G - Palm Pre - Motorola Q - PCD XV6700/PPC-6700 - Hitachi SH-P300 - Sony Ericsson T608 - Samsung SPH-N200
  16. #16
    IT IS NOT STOCK, it's from the Samsung Apps Program. If your phone came pre-installed with it, that's another issue, but many here know it's not a stock widget... When you first get your phone if you updated the Samsung Apps Program it may auto-install, but not a single person I know with a stock S3 has that widget... Maybe you should learn to be respectful of people that "actually know" what they are talking about...
  17. #17
    I FOUND IT!!!!! ok so I just got the galaxy 3 I had the galaxy 2 before and I was always monitoring my usage w/ the lil application monitor icon and whe I couldnt find it on the galaxy3 I freaked! but thankfully I found it by mistake because I was just pushing buttons and there it was! so here is how u find it I hope my explanation is clear...
    press down on the home button (the only button on the face of the phone) it will then take you this screen w/ different apps and things, well at the bottom of that screen you will see a circle type
    icon a g and a trash can.. click on the circl type icon and YAAAAAY WE FOUND IT!!!!!!!!:-):-):-):-):-):-):-)
