Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By killakel77
    Default Sprint Connection Optimizer: Battery Saver or Drainer?
    Observations/thoughts/opinions welcome.
  2. #2
    Default Re: Sprint Connection Optimizer: Battery Saver or Drainer?
    I don't know if anyone can answer. I've never heard of people using it.. Only people turning it off :P.
    I keep it off because I know when I'm near wifi I want to use so.. It's a quick swipe down of the notification bar and then tap wifi.. And then when I know I won't be near one that I would want.. Repeat the process and keep wifi off.
    Sent from my Sprint S3 using AC forums
    Thanked by:
  3. #3
    I use Sprint Connection Optimizer and I don't know if it made a difference or not. But I can tell you this, I only have to charge my phone once a day with constant usages.
    Thanked by:
    qbngator likes this.
  4. #4
    rando991's Avatar
    Posts
    ROM
    Stock/Rooted
    I use it all the time with the Epic 4G and will plan to use it on the SGIII. I like not having to remember to turn wifi on or off. I think it saves battery.
  5. #5
    Aside from the battery, I think it's a security issue. Right after I got this phone, I had to do jury duty in LA and the jury room had free wifi available. Of course it was unencrypted. While I was waiting, I was handling some pretty sensitive corporate emails, and got this message that there was an unsuccessful unauthorized log in attempt. That freaked me out. I remembered that the connection was unencrypted and quickly turned off wifi. And on throughout the day, the wifi would magically turn itself on without me toggling it. At the time, I couldn't figure it out. I eventually figured out later that it had this new functionality. An environment like that would be the perfect setting for a thief to setup in the corner and sniff the unencrypted data being transmitted. You would think that they would imbed some sort of feature where it wouldn't automatically connect unless it was encrypted or at least prompting me first.
    From what I've seen out there, most casual smartphones users aren't all that sophisticated. Most don't know about security issues related to networks and data. They probably couldn't even navigate through advanced settings if their lives depended on it.
  6. #6
    I turned the astrophysical automagical setting off also, always wondering...
    Sent from my SPH-L900 using Tapatalk 2
    EVO & an Acer A500 tablet.
    My files: http://www.appbrain.com/user/bclinge...the-htc-evo-4g
  1. Uninstalled Easy Battery Saver & Can't Connect to Network?
    By brettnussb in forum Sprint Nexus S 4G
    Last Post: 02-04-2013, 12:56 AM
  2. Replies: 2
    Last Post: 11-05-2012, 10:19 AM
  3. Turning off Sprint Connection Optimizer on JB?
    By ExTheGod in forum Sprint Galaxy S3
    Last Post: 10-31-2012, 09:26 PM
  4. Droid connection Problem (no 3G or 1x)
    By corydunbar in forum Motorola Droid
    Last Post: 09-07-2012, 05:19 AM
  5. New Sprint update and battery life
    By lastdetailwd in forum HTC Hero
    Last Post: 11-23-2009, 12:26 AM
