If you want to disable it again just follow the instructions below.
Edit: Forgot to mention this is a reminder in case your wi-fi gets "stuck" (you see you are connected to your network yet are getting no data)
1. Go to your phone dialer
2. Dial *#0011#
3. When you see the "ServiceMode" screen, press the left menu button
4. Select "WiFi"
5. See that "Wifi Power Save Mode" button that is "ON" - well turn it "OFF"
6. Exit this menu, turn off your Wifi and turn it back on. If you already entered all your wifi credentials, forget your network info (remove it) and re-enter it again.
2. Dial *#0011#
4. Select "WiFi"
