1. arhoolie's Avatar
    Hi folks,
    I just migrated to the S III from an EPIC 4G on Black Friday. One of the first things I noticed was the crummy battery life I was getting and Media seemed to be the primary culprit. I've been lurking for awhile and read the threads on this issue. All I've done so far to resolve is to pull my microSD card to see how that affects things. And what I saw was a significant improvement in battery life.
    So here's my two questions:
    1. I'm about to reformat the microSD card and have seen references to some software from Easus called Partition Master to do this. Is there a good reason why I should use Easus? Why can't or shouldn't I simply open a DOS command window and reformat the card (as fat32) using the DOS reformat command?
    2. Once the reformat is complete, how do I go about rebuilding the directory structure on the card? Do I have to do this manually? Or do my apps take care of this for me?
    Thanks in advance,
    12-11-2012 11:05 PM
  1. Fixed my Battery drain issue!
    By Grenex in forum Verizon Droid Charge
    Last Post: 08-16-2011, 05:41 PM
  2. Battery drain issues? READ THIS BEFORE BLAMING ROMS
    By obijohn in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 05-03-2011, 08:53 AM
  3. Battery Drain Issue using WHERE
    By Phaise in forum Virgin Mobile Optimus V
    Last Post: 02-02-2011, 04:11 PM
  4. Battery drain issue
    By mbuxx in forum Telus Fascinate
    Last Post: 01-08-2011, 12:17 PM
  5. Possible battery drain issue.
    By Nodnerb in forum General Help and How To
    Last Post: 06-21-2010, 10:10 AM
