DEAL OF THE DAY: Save 37% on the Seidio SURFACE Case for Samsung Galaxy S4!
Results 1 to 9 of 9
Like Tree2Likes
  • 2 Post By Atlienzz
    Default Odd Weather Widget thing when I unlock the phone...help.
    When I turn on the phone and swipe through the lock screen to get into the phone...I get a weather "thing" floating across the screen (clouds, windshield wipers, sunshine, etc) that I either need to wait to go away (roughly 5 seconds or so) or I need to tap the screen for it to go away. My wife's S3 doesn't do this nor my other friends who have it.
    What is it?
    Why is it there?
    I can't find a single reason in settings that it is happening.
    Thank you all.
  2. #2
    Default Re: Odd Weather Widget thing when I unlock the phone...help.
    What weather app are you using? This is a feature in at least one weather app (that I'm aware of); animation. You should be able to shut it off by going into the app's menu and turning off the animation feature.
    Quote Originally Posted by Ntchwaidumela View Post
    I have the stock weather app (on the widget with the clock and calender) and The Weather Channel app (which I deleted) but it still is happening.
  4. #4
    Atlienzz's Avatar
    Posts
    ROM
    ACS Syndicate Frozen 1.1
    Do you have beautiful widgets?
    Yes, but I'm not currently using any of them...after the last update the really great clock/weather widget they had was deleted. Do you think that's it?
  6. #6
    Atlienzz's Avatar
    Posts
    ROM
    Well all I can say is I had the exact same issue as you and didn't like it, I went into the beautiful widgets settings and turned off "unlock animations" and it went away. Even though you may not be using the widget it could still be causing your issue, it's worth a shot.
    Thanked by:
    Ntchwaidumela and fetterjohn like this.
    Quote Originally Posted by Atlienzz View Post
    Genius!!! You sir are my hero...
  8. #8
    That's exactly what I thought was causing it, which is why I asked what weather app fetterjohn was using. It was particularly annoying on my tablet. I shut down Beautiful Widgets and Beautiful Widgets Animations. I use BeWeather Pro as my weather app, and find it to be excellent.
  9. #9
    I use HD widgets. Can have them outrageous or have them minimalistic depending on my mood. So far, I have not had a problem with them detecting where I'm at. Including small little shiot holes in the middle of nowhere!
  1. Guess what happens when you use the phone button in Odin.
    By gunnermike53 in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 03-16-2012, 05:32 PM
  2. Data usage when unlocking the phone?
    By donavan in forum AT&T LG Phoenix/Thrive
    Last Post: 01-13-2012, 11:54 PM
  3. Payment when ordering over the phone?
    By ISUVetMed in forum Verizon HTC Thunderbolt
    Last Post: 03-16-2011, 01:39 AM
  4. Contacts when you hit the phone button problem
    By sonar_chris in forum Verizon Droid Incredible
    Last Post: 08-09-2010, 06:25 PM
  5. A way to use the scroll button to unlock the phone?
    By Nephilim_80 in forum Verizon Droid Incredible
    Last Post: 06-18-2010, 09:07 AM
