1. cb2367's Avatar
    How is it possible for the display to be using a good portion of the battery when power save mode is enabled and display is locked? With the display using most of the battery, I can only get about 4 hours of use before the battery has to be charged.
    04-06-2013 06:06 PM
  2. cyanogen-man's Avatar
    Because the display not only shows everything there's a digitizer that's actively working in tandum with the screen and depending on the brightness of the panel the can effect it as well
    Sent from my HTC One X+ using Android Central Forums
    04-06-2013 06:09 PM
  3. cb2367's Avatar
    I have power save enabled. Auto brightness is selected. The screen times out after 30 seconds.
    I will start up Pandora and then lock the phone. I'll only unlock the phone and use the display if I need to search something on the internet or if I need to turn the phone off.
    It looks like I'm now going to have to carry around an extra battery to get through the day, just like I had to eventually do when I had the Samsung Epic.
    04-06-2013 06:25 PM
  4. cb2367's Avatar
    I started with a full charge and got 4.5 hours out of the battery. I've now got just 2% left as I write this. I'd like to know how to get more use out the battery.
    04-06-2013 06:43 PM
  5. Gator352's Avatar
    Take it off auto brightness and set it to about 1/4 and try that. Sometimes auto brightness gets stuck (even if the screen is off) tricking the digitizer to thinking it's still active.
    Ntchwaidumela likes this.
    04-06-2013 08:09 PM
  6. Almeuit's Avatar
    Post pictures of your screen on time and battery (examples below)
    Sent from my Sprint S3 using AC forums.
    Attached Thumbnails Display using most of battery-uploadfromtaptalk1365298768956.jpg   Display using most of battery-uploadfromtaptalk1365298775675.jpg
    04-06-2013 08:39 PM
  7. Almeuit's Avatar
    Oh sorry.. Also post the graph (below) so we can see what's going on.
    Attached Thumbnails Display using most of battery-uploadfromtaptalk1365298826926.jpg
    04-06-2013 08:40 PM
  8. GiantJay's Avatar
    Are you using WiFi or 3g data or LTE. This would be a very big issue depending on what you are using. If you use data in a bad signal area this will drain your battery faster than pretty much anything else.
    04-08-2013 04:42 AM
  9. dominick's Avatar
    ditto.
    unless i am in direct light, i always set display to zero. and physics will tell you that it takes a lot of energy to move electrons from 0-state to active - so if you're turning on the display from sleep frequently, or are watching a video, or playing games... this display activity uses a lot of energy.
    cheers/dom
    04-08-2013 01:00 PM
  10. cb2367's Avatar
    Well another day and just 4 hours of battery life. I will have to post the screenshots the next time the battery runs down.
    I'll try taking auto brightness off and see if it offers any improvement.
    As far as signal, I primarily get 3g, but very slow 3g and lately I don't get any service in certain areas.
    04-08-2013 11:45 PM
  11. meyerweb#CB's Avatar
    Four hours is not just the screen brightness, unless you have the screen on for almost all of those four hours. Something is running wrong. Taking and posting those screen shots is the first step toward enabling us to help you.
    04-09-2013 09:19 AM
  12. Golfdriver97's Avatar
    I agree that auto brightness does suck in terms of battery life. Part of your problem may be the weak 3G signal. I would suggest that when you are working or at school (or any other reason you would not need your phone to catch a signal), just turn Airplane Mode on. That will turn the radios off but keep the phone on. Any cellular phone will spend a lot of battery life searching/maintaining a weak signal. You can also try to go into Settings>Update Device>and update your PRL and Profile.
    04-09-2013 09:22 AM
  13. Almeuit's Avatar
    Weak 3g would be the killer but honestly... We can't diagnose anything without those screen shots that I talked about. For all we know your phone is running some app in the background that's keeping your phone constantly awake and then would drain your battery very fast.
    04-09-2013 04:18 PM
  14. Golfdriver97's Avatar
    I am highly inclined to agree. To the original post...if you need to figure this out start uni stalling apps till you get to out of box. Then slowly reinstall. Either the weak signal or an app is killing your battery. If you dislike the idea of removing apps...fine. Enable airplane mode for the better part of the day. Tell every one you know what you are doing. Check for texts/calls every couple hours but thats it. See what happens.
    04-09-2013 11:47 PM
  15. Ntchwaidumela's Avatar
    Turn off Power Saver mode. It doesn't help. I turned it on when I first got this phone, but turned it off within a month. I've never turned it back on and I actually get more life out of the battery.
    04-10-2013 07:10 AM
  16. Ntchwaidumela's Avatar
    Also turn off auto brightness. Set it to the lowest setting that works for you. You can always adjust the brightness manually.
    04-19-2013 12:41 AM
  17. Binish Rizwani's Avatar
    Do you keep a lot of app icons on your home screen? I noticed a huge change in my battery life when I removed most of them and just kept some i regularly used. Before this I used to have a short cut of just about every app on my home screens.
    10-07-2013 02:43 AM
  1. Replies: 21
    Last Post: 10-12-2012, 06:56 PM
  2. Standby using lots of battery
    By herbmmm in forum Verizon Droid Incredible
    Last Post: 05-23-2011, 05:19 PM
  3. Maps using 86% of battery?
    By Dark_Blu in forum HTC EVO 4G
    Last Post: 01-20-2011, 08:21 PM
  4. Replies: 10
    Last Post: 12-20-2010, 09:47 AM
  5. Now my android system is using 54% of battery...yikes!
    By hawaiijedi in forum HTC EVO 4G
    Last Post: 11-17-2010, 03:44 PM
