cgc32
Re: Galaxy S3 battery died, now wont charge and wont turn on!!! HELP!
This happened to me too! THANK YOU!!!!!! You saved my phone!!!
Hello, I know this post was some time ago but did you get it sorted, if so how because mine is now dong the self same thing and I can't turn it on .
the solution of non charging is very simple
http://forums.androidcentral.com/general-help-how/312596-samsung-galaxy-charging-issue.html
Ask them to send it back unrepaired and get a wireless charging solution (replacement back and Qi charging pad).now they are claiming water damage to the tune of $300 to get the phone back
