Results 1 to 12 of 12
    slyder0244's Avatar
    Posts
    Global Posts
    62 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Android OS battery drain
    I'm coming from IOS, but I have an android tablet. I just got a used Sprint Galaxy S3 last night. The first thing I did was update OTA to 4.3, and then root it. I've installed Wakelock Detector and Greenify, which I've been using since last night and I've already hibernated some apps. I've also installed ROM toolkit lite and frozen several apps to try to deal with the battery life. I've never seen battery drain like this on my tablet. The top 2 on there are screen and wifi, while on the S3 it's Android OS. It spent most of the day turned off, and I even charged it for over an hour at the computer.
    I don't plan on activating service on it for now. I'm just using it as an iPod replacement, so I also put it into airplane mode and just turned on wifi. Any ideas on how to fix the battery drain problems?
ID:	100091Click image for larger version.
ID:	100093Click image for larger version.
  2. #2
    AxlMyk's Avatar
    Posts
    Global Posts
    1,244 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Android OS battery drain
    My Verizon GS3 has higher battery drain also. I think it's because the screen is brighter than before 4.3
    slyder0244's Avatar
    Posts
    Global Posts
    62 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by AxlMyk View Post
    Check your battery stats to see if it's the screen.
  4. #4
    AxlMyk's Avatar
    Posts
    Global Posts
    1,244 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by slyder0244 View Post
    Umm, no kidding?
    Been there, done that. Yep. That's what it is.
    The screen is brighter than before 4.3, so, it's using more power.
  5. #5
    meyerweb's Avatar
    Posts
    Global Posts
    10,319 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    In the OP's pics, the screen is only using 15%, and the OS is responsible for 75% His problem isn't the screen.
    OP, I would strongly suggest going back to stock and seeing where you battery life is. You'e made so many mods and installed so many apps that affect how the phone works, and how it uses battery, we'll never figure out what's going on. I have no battery saving apps installed and generally get about 12 hours before I get down to 30% left. And that's fully activated, with email syncing and a fair bit of use.
    My advice is to factory reset, and if you're still having battery life issues install ONLY wakelock detector, so that you can figure out what's going on.
    slyder0244 likes this.
    slyder0244's Avatar
    Posts
    Global Posts
    62 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by meyerweb View Post
    I rooted it and hibernated 4 apps, but I hadn't frozen any apps until today when I saw the battery was draining so quickly. I just factory reset it and I haven't rooted, just installed Wakelock Detector. I'm going to let it run while I charge it tonight, and see how the battery life is tomorrow. I'll report back with how it goes, thanks for the help meyerweb.
    slyder0244's Avatar
    Posts
    Global Posts
    62 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Here is the update. Did a reset and battery life was significantly better today. Still the Android OS is taking up a lot of the battery. Is this usage normal? The drop off near the end is due to me playing some Angry Birds, watching a little youtube, and reading reddit. After seeing how well it was doing I decided to try to put it to a better test.
ID:	100195Click image for larger version.
ID:	100197Click image for larger version.
    Attached Thumbnails Attached Thumbnails Android OS battery drain-screenshot_2014-01-08-21-13-10.png
  8. #8
    meyerweb's Avatar
    Posts
    Global Posts
    10,319 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Android OS is often the highest consumer on my phone since the upgrade to 4.3, too, but I'm getting as good as, or slightly better, battery life than I did on 4.1.2. I think a lot of what used to be separate processes, which individually didn't use enough battery to show up on the list, have been consolidated into the OS.
    Your battery life doesn't really seem all that bad. It's on par with what I get, but without knowing how you use your phone it's hard to compare.
    The one thing that does seem odd is the VM wake time. Did someone leave you a very long message?
    slyder0244's Avatar
    Posts
    Global Posts
    62 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ok thanks meyerweb. My android tablet is stuck at 4.1.1 so I never see that in the battery stats, wifi and screen are always at the top on it.
    Yeah I got more than double what I got yesterday so I'm a lot happier with this. I was just hoping I could reduce that Android OS down. If not then that's ok my battery life is still doing pretty good. I've now greenified Amazon App store, and I've frozen all the Samsung and Sprint apps. I'm just using this as an ipod replacement for now so the phone isn't even activated.
    So that voicemail process also confused me, but it's frozen now hopefully that'll put an end to that. Do you know if it's ok to hibernate Google+? I don't use Google+ but I didn't know if that would interfere with any of the other Google apps, such as Gmail or Hangouts. As an ipod replacement I really just want to shut down all the phone functions, and other battery hogs to squeeze out as much battery life as possible. While also keeping it functional for messaging, web surfing, gaming, reading news, emailing, watching videos, and listening to music.
  10. #10
    meyerweb's Avatar
    Posts
    Global Posts
    10,319 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You shouldn't expect to get the same battery life out of the phone as a tablet, if that's your basis of comparison. Tablets have much, much larger batteries.
  11. Thread Author  Thread Author    #11
    slyder0244's Avatar
    Posts
    Global Posts
    62 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No no I wasn't comparing battery life between the two. I was just comparing what took up the most battery life percentage wise in the battery stats. Actually I think this phone is getting better battery life than my tablet, but it's about 2 years old.
  12. #12
    meyerweb's Avatar
    Posts
    Global Posts
    10,319 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    OK, I understand now. Enjoy your S3.
  1. how can i get better battery life ?
    By tashauphill1994 in forum Sony Xperia Z
    Last Post: 05-14-2014, 04:20 AM
  2. No Mobile Network and "unfortunately, the process com.android.phone has stopped"
    By jmklei0 in forum Verizon Galaxy Nexus Rooting, ROMs, and Hacks
    Last Post: 05-02-2014, 10:05 PM
  3. newbie question re android search
    By retired05 in forum General Help and How To
    Last Post: 02-14-2014, 05:41 AM
  4. Severe Android OS kernel battery drain
    By ldolezel in forum Samsung Galaxy Note 3
    Last Post: 01-08-2014, 10:10 AM
  5. Battery life on nexus 5?
    By Jake_15 in forum General News & Discussion
    Last Post: 01-07-2014, 10:57 PM
