Results 1 to 5 of 5
    Ytsejamer1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Lightbulb FYI: Battery Drain? Try this...
    Hey all!
    One of the many app updates came down recently and I noticed a big battery drain...with Google Services being the big culprit. I think I found a couple things to switch off and have noticed a HUGE improvement.
    1. Settings>More>Location Services. Uncheck Use Wireless Networks.
    2. Open Google Now>Settings>Accounts & Privacy>Google Location Settings>Set Location Reporting to OFF.
    Everything else seems to work normally and after nearly 18 hours, I've used only 25% battery after above average usage. Prior to the two changes, it would take about two hours to get to use 25%.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,091 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: FYI: Battery Drain? Try this...
    Thanks for the heads up.
  3. #3
    HULKchampion's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the input. I'll try this out. Hopefully this won't effect the phone with my daily usage.
    Update:16Jan14
    I had to turn those two options back on. For sometime, it seemed to work well but than my "Notification Weather Premium" application started acting up. Not detecting location or constant network error while I was 3g, 4g or WiFi.
  4. #4
    prboy1969's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you have excessive Battery Drain. First find out what's causing it. BBS ( Better Battery Stats ) is good for that. Also if you want to squeeze a bit more out of the Stock Battery Greenify does really help. Simple, and easy to use.
    Ytsejamer1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My change was making a big difference at first, but it seems like after a few other app updates, it's not lasting as long now. I'll keep things off as everything was working normally for me...but yeah, I got excited about a potential of a quick solution.
  1. LG G2: Update this morning
    By jmarkey77 in forum LG G2
    Last Post: 01-31-2014, 09:51 PM
  2. Droid Maxx: Crazy battery drain
    By rescue56100 in forum Motorola Droid MAXX
    Last Post: 01-22-2014, 09:01 PM
  3. Woke up this morning and...
    By Harvinder Sunila in forum Moto G (2013)
    Last Post: 01-15-2014, 11:00 AM
  4. Replies: 0
    Last Post: 01-15-2014, 09:49 AM
  5. Replies: 4
    Last Post: 01-15-2014, 08:47 AM
Tags for this Thread
