Results 1 to 5 of 5
    wowzem's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default GS3 Shuts Down Due to Dead Battery but Battery is NOT Dead!
    I had an S2 that stopped recognizing a charged battery. I could power it up and as soon as the Sprint logo screen appeared it would shut down. It would display gray dead battery but if you held the power button for a sec it showed the actual green fully charged battery. Worked OK as long as plugged into the wall but died the instant you unplugged it. Put in a new battery, no change. Took it to Sprint store and they said too bad, you need a new phone. Replaced the 2 year old S2 with a new S3. The S3 is now 2 years old and just died. It is doing EXACTLY the same thing. It does not recognize the fully charged battery, thinks the battery is dead. Works fine plugged in but dies the instant you unplug it. Will turn back on but shut down as soon as the Sprint logo splash ends. What gives???
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    77,961 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Default Re: GS3 Shuts Down Due to Dead Battery but Battery is NOT Dead!
    Welcome to Android Central! Although you said that trying a new battery didn't help with the older S2, did you try a new battery with the S3? It's still very possible that your current battery died. A quick way to tell is to remove the battery, place it flat on a table, and try to spin it. If it spins freely, it's bulging in the middle, which is a bad sign. But even if it doesn't spin, it's worth trying a new battery.
  3. #3
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    http://www.amazon.com/gp/aw/d/B00975...cUvbUpU3807079 is a good deal for replacements.
    You could also try resetting your battery calibration data. You'll need to root the phone in order for this to work (ex. https://towelroot.com/); once you do, install BatteryCalibration http://market.android.com/details?id...erycalibration and run it.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
  4. #4
    coreopsis31's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have the same issue and a new battery and did the calibration. Still the same problem. Any answers would be appreciated.
  5. #5
    Mista_J's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Hydrokernel on Optimus S
    Got the same problem with my wife's phone.
  1. Replies: 1
    Last Post: 03-30-2015, 02:31 AM
  2. Replies: 0
    Last Post: 08-02-2014, 12:03 AM
  3. Galaxy tab 3 - apps won't run (drop out to main screen)
    Last Post: 08-01-2014, 11:20 PM
  4. Replies: 0
    Last Post: 08-01-2014, 11:00 PM
  5. Problem with Galaxy S4 flashed from Sprint to Cricket
    Last Post: 08-01-2014, 10:52 PM
