Page 1 of 2 12 LastLast
Results 1 to 25 of 43
Like Tree1Likes
    Default Problem. Only a few seconds of LTE. Please Help
    So i got my G2 yesterday in a corporate store and i am truly in love with it. coming from and Evo 3D. It was a HUGE upgrade. My problem is the freaking LTE connectivity. The phone only gets a few seconds of LTE and then it just switches back to 3G and stays there. I have literally tried EVERYTHING. updated profile, PRL, set it from global to LTE/CDMA, turn off Connection Optimizer, restarted it. Literally everything and nothing. Every time i do something, LTE turns on and a few moments later 3G. I live in NYC where their LTE towers are ON so i am VERY mad at this. You would think that their first SPARK device would at least receive the original 1900 MHz 4G LTE signal until the "Spark" update. SMH!
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,670 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Problem. Only a few seconds of LTE. Please Help
    Have you contacted the store about it yet?
  3. #3
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Quote Originally Posted by Joseph M View Post
    How strong is the LTE? If it's weak I wouldn't expect it to hold onto it as it wastes more battery than only using 3G.
    I haven't contacted the store yet since they are usually no help. Only thing they could help on is if its a hardware problem, which i doubt. The signal is pretty strong. I have done test.
    I turn Airplane mode ON and OFF to make the phone find the LTE signal. Once i get it, i immediately run a speed test. I get 50-70 pin, 15-25 Down and 4-7 UP. Sometimes the speedtest cant even finish because it switches right back to 3G.
  5. #5
    Yeah I'm having the same problem. My S3 was able to hold onto an LTE signal pretty well, but the G2 can't for some reason. I've also tried everything you've tried, and am getting the same result: LTE for a few seconds, then back to 3G
    Sent from my LG-LS980 using Tapatalk
  6. #6
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    This does sound like a hardware problem. If it"s good signal strength it shouldn't be losing it
    The thing is, if it would had been any other LTE phone thats out. I would had immediately thought it was the Hardware, but this is a new phone that came out and the first Tri band phone. So my first thoughts was that something might be conflicting with the 3 LTE frequencies, even though sprint hasn't sent an update for them. But you never know, it could had been a bad batch of phones.
  8. #8
    Its not a bad batch of phones, look through all the forums for sprint. Unfortunately it seems to be a widespread issue at moment. I actually have had mine for two weeks same thing. CSR are useless
  9. #9
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Quote Originally Posted by darryjr View Post
    Wow
    Sprint fails to deliver again
  10. Thread Author  Thread Author    #10
    I guess well just have to wait for a dam update -___-
  11. #11
    I guess well just have todam update -___-
    I also have static during a call, weird thing is if I roam, call is normal, when not roaming, static and popping. Went to corporate store and they had no idea what to do. I did not get phone from sprint or bb I actually picked it up in new Hampshire pre release and live in NY. As far as the static, I also read that is common on Verizon, haven't seen it with sprint, except mine at this point. Hopefully they update soon.
  12. #12
    I'm having the same issue. This really pisses me off. I come back to sprint and this is what happens.
  13. #13
    Quote Originally Posted by moonoverparma00 View Post
    Are you having the lte issue or the static and pop in call that I spoke about?
  14. #14
    Make sure that under Mobile Networks your network mode is on LTE/CDMA and connections optimizer is unchecked. It fixed the problem i was having.
  15. #15
    Default
    The LTE issue. I have CDMA/LTE selected and connections optimizer turned off and still have the problem
  16. #16
    jfenton's Avatar
    Posts
    Global Posts
    747 Global Posts
    I had the problem but disabled the optimizer, switched from Global to CDMA / LTE and updated the profile and now it seems to work like a charm
  17. #17
    Quote Originally Posted by jfenton View Post
    I'll give that a try.
  18. #18
    headbuzz's Avatar
    Posts
    Global Posts
    19 Global Posts
    I have global enabled..no issues with LTE so far. Even the switch from 3g to LTE is almost immediate.
    Sent from my LG-LS980 using AC Forums mobile app
  19. #19
    Default
    Mine will not connect to LTE at all while on global. When I switch to CDMA/LTE, it will connect only for a few seconds and then drop out. I have to force it to connect again but will still drop out after a few seconds.
  20. #20
    you are probably in an area where the towers are compatible with the device. I suspect if you took your phone to the same location moonverparma00 is you would have the same issue as he is having
    Quote Originally Posted by headbuzz View Post
  21. Thread Author  Thread Author    #21
    My question is. Will they have a fix for the NV towers and the legacy towers conflicting with each other and not being compatible with the phone?, or is this something that you just luck out if you live in the wrong place? This seems like a serious problem so i would like to know. I only have 14 day to return the phone and cancel this JOKE of a service.
  22. #22
    Sprint better come up with an answer fast because if I can't take advantage of the LTE in my area, I want to return this phone within my 14 days.
  23. #23
    Just got my LG G2 and having the same issue connecting to 4G/LTE. My wife got a Galaxy S4 about two weeks ago and she hasn't had any issues getting 4G/LTE to connect.
    I tried the suggestion of switching the Mobile Network setting and it hasn't made any difference, I'm still just hitting 3G. It's flashed to 4G/LTE a few times but it's been for maybe a second or two at a time. I've pretty much had nothing but problems since getting the phone three days ago.
    - Can't get it to connect to my MacBook
    - Can't get 4G/LTE
    - Wasn't receiving text messages from anyone with iPhones
    I love this phone but I'm becoming annoyed with it very quickly. I'm half tempted to return it for a Galaxy S4. My wife hasn't had ANY of these problems with her phone.
  24. #24
    eptiger's Avatar
    Posts
    Global Posts
    61 Global Posts
    Carrier
    Gingerbread
    I assume this is the problem:
    Nexus 5 and LG G2 experience temporary Sprint LTE connectivity issues due to Circuit Switched Fallback technology - Sprint 4G Rollout Updates
    So there's no toggle between 3G and LTE if I want to turn on one or the other? It just autodetects? I'd rather be able to control that myself. I'm not able to find the toggle for it, at least. I have my mobile networks set to global. What's the difference between global and cdma/lte?
    Elton
    Jawbox likes this.
  25. #25
    Quote Originally Posted by eptiger View Post
    Elton
    No, Elton, there is no toggle to choose between the 3G and 4G/LTE. It's very frustrating to have a new phone that won't even pick up a 4G network. One of the reasons I chose to upgrade was because my iPhone 4S was only capable of picking up 3G. Now, I've spent $200 to upgrade to yet another phone that will not pick up a 4G network. None of the file transfer programs work with this phone, and 4G doesn't work with this phone. I will probably have enough of it by the end of the week, return it, and spring for a Galaxy S4. It's a real disappointment, I'd really been looking forward to the LG G2...all for nothing.
  1. Help to delete multiple sms / text messages at one time
    By dpoverlord in forum Samsung Galaxy Note 3
    Last Post: 10-09-2015, 10:33 AM
  2. S4 Verizon all of my contacts don't show up in sms list
    By brianmac1 in forum Samsung Galaxy S4
    Last Post: 11-27-2013, 02:32 PM
  3. Just ordered a few questions....
    By prissysox in forum Moto X (2013)
    Last Post: 11-15-2013, 06:01 PM
  4. Replies: 20
    Last Post: 11-10-2013, 11:39 AM
  5. 4.3 Update for Wifi-Only Galaxy Note 8.0?
    By rkeenan in forum Samsung Galaxy Note 8.0
    Last Post: 11-09-2013, 12:03 PM
