1. Hvacmanjc's Avatar
    Hello everyone. Does anyone have any idea or explanation why the location icon(teardrop)is always on in my notification bar? Seems like its draining the battery. Is it suppose to always be up there? Didn't notice it when I first got the phone. Thanks
    Sent from my LG-LS980 using AC Forums mobile app
    07-19-2014 09:45 AM
  2. TonyLibations's Avatar
    I can't say what's causing, but I can tell you that it shouldn't always be there.
    Sent from The LG-G2.
    Hvacmanjc likes this.
    07-19-2014 10:11 AM
  3. Mikey47's Avatar
    Go into Settings and select Location. This will tell you what apps have used "Location" recently and what accuracy mode it used. You might see an app there that you just installed that isn't behaving properly.
    The only times you should see it there continuously is if you're doing navigation or a GPS type app (like a speedometer or car app).
    07-19-2014 01:05 PM
  4. Hvacmanjc's Avatar
    This is the only things I see under the location settings. As you can see, the location icon is gone now because I turned my phone off and on. It has been on constantly for roughly a week. Now that I reset it. It will come back on sometime tonight.
    07-20-2014 07:56 PM
  1. Replies: 10
    Last Post: 02-27-2015, 02:25 PM
  2. Help, Root Galaxy Core 2 Duos
    By bog3ls in forum Ask a Question
    Last Post: 09-15-2014, 04:21 AM
  3. Navigation app with multiple stops.
    By lornaevo in forum Google Nexus 5
    Last Post: 07-19-2014, 01:28 PM
  4. wifi help newbie
    By riot1002 in forum Samsung Galaxy Note 3
    Last Post: 07-19-2014, 10:33 AM
  5. using gear fit with Samsung galaxy s4
    By Unregistered in forum Ask a Question
    Last Post: 07-19-2014, 08:07 AM
