For those who don't frequent the XDA forums, you might have missed this important fix after the latest ZVD update:
If you have noticed after the ZVD update you seem to be on 3g a lot and seem to have problems staying on LTE in locations you previously had good signals, here is a fix I shared in the ZVD update thread which seems to completely resolved the issue:
1. Obtain your MSL
2. open the dialer and enter ##data#
3. Tap LTE and select edit
4. Enter your MSL
5. Select BSRTimer (defaults to 3000) and change the value to 3
6. Press back, phone should reboot
7. Profit
*does not require root
After doing this, I'm back to nearly constant LTE connectivity, where prior to the fix I was on 3g almost every time I checked.
1. Obtain your MSL
4. Enter your MSL
7. Profit
