1. two-rocks's Avatar
    So thanks to another thread and post by rawvega [including the image below], I decided to actually remove the wrapping from the manual, and low and behold:
    DO you see it? There is supposed to be an indicator LED....so how do we use it!!!
    10-20-2011 01:16 PM
  2. rawvega's Avatar
    I have no idea. I figure either LG made a mistake in the manual and it actually doesn't have a notification LED or it's something that LG needs to activate via a firmware update. Or perhaps an app or a custom ROM get it to turn on. I dunno, it's not my phone so I haven't investigated it too thoroughly yet.
    10-20-2011 11:00 PM
  3. forsignup's Avatar
    I do not know, I am using an app alled "NOLED" now.
    10-21-2011 07:03 PM
  4. redoscar3's Avatar
    Doesn't this phone also have a front facing camera? No where on the manual page do I see that feature listed. I'm guessing the Notification LED was a feature that didn't make it to the actual phone. I don't understand why a feature as useful and inexpensive as a Notification LED gets held back on all these devices.
    10-22-2011 08:43 AM
  5. nosajsam's Avatar
    Yes it does have a front camera. I personally do not think this manual is accurate. I'm not even sure its a matter of turning a notification LED on/off as I have the phone in my hands & don't see an LED where according to the manual its supposed to be. With that said, if it has it & we can find how to toggle it on/off that would be great but in the meantime I am using the NoLED app & it works just fine.
    10-22-2011 11:46 AM
