Results 1 to 3 of 3
    KillerQ's Avatar
    Posts
    Global Posts
    258 Global Posts
    Default Will the Samsung Epic 4G battery fit the Samsung Nexus S?
    Hey all,
    I am surprised I didn't see this question asked more often (I searched). Will the stock battery on the Epic also fit in the Nexus - or is it a different size alltogether....
    Thanks,
    Matt!
  2. #2
    intheb0x's Avatar
    Posts
    Global Posts
    949 Global Posts
    ROM
    Only Jelly Bean or ICS!
    Default Re: Will the Samsung Epic 4G battery fit the Samsung Nexus S?
    nope i got both right here and tried.
    If you think i helped you, please click the Thanks button on the right
    KillerQ's Avatar
    Posts
    Global Posts
    258 Global Posts
    Quote Originally Posted by intheb0x View Post
    bummer - thanks a ton!
