Results 1 to 19 of 19
    Default problems with sd card mounting
    I keep having this issue with my phone not mounting the sd card when I reboot it.Im rooted and have flashed the GWK74 UPDATE.I have the matrix 7.0 kernel installed also.Can someone shed some light on this problem ?
  2. #2
    BlackHawkA4's Avatar
    Drop the Bag
    Posts
    Global Posts
    2,424 Global Posts
    Default Re: problems with sd card mounting
    The problem is you don't have an SD card nor do you have a slot to put one in.
    jk.
    Did you try it without matrix? or try reflashing the rom?
    Yes I tried both methods already still have to reboot phone several times before sd card mounts
  4. #4
    Default
    Have you tried another SD card? Or that card in an alternate device? It could be a card issue.
    Sent from my Sensation using Tapatalk
    Nexus s 4g doesn't have a removeable card
  6. #6
    grantheppes's Avatar
    Posts
    Global Posts
    420 Global Posts
    ROM
    AOKP
    Quote Originally Posted by evoldroid View Post
    Boot into Clockwork Mod. (When phone is off hold up volume and power, then choose recovery).
    Go into mounts and storage.
    Mount /sdcard
    Then Reboot.
    Not sure if that will solve it, but worth a shot.
    Edit: I really hope you dont think there is an actual sd card in there.
    - Grant Heppes www.GrantHeppes.com www.about.me/GrantHeppes
    Thank me if I helped you please. Google+ Me http://www.gplus.to/GrantHeppes
  7. #7
    Default
    Ahh sorry. Must have missed the device being the Nexus 4g o_O
  8. #8
    A Lex and Er's Avatar
    Posts
    ROM
    AOKP
    If you are still having this issue I may have a answer for you.
    I believe you are running a non-stock kernel? Matr1x?
    With whatever method you chose, I use setCPU, raise the voltages by 5% at a time. A reboot is required after raising the voltage's, in fact two or three maybe needed before the change takes affect.
    I have had the same issue and after much playing have stabilized my NS4G getting rid of my mounting issues, I can not over clock past 1.2GHz and really only raised voltages by 5% but more maybe needed, if I do it always results in the same un-mounted sdcard/internal storage. It still does un-mount every once in a while but it's so rare now I don't even think about it.
    I hope this helps you, have a great weekend!
    aLeXandEr's
    G_Nex
  9. #9
    are u using bfs matrix kernal. mine did that using bfs but with cfs worked fine...hope that helps
  10. #10
    Angrygimp's Avatar
    Posts
    Global Posts
    29 Global Posts
    ROM
    Bugless Beast GPA19
    Using the newest matrix CFS and mine does the same thing. Sometimes fixes itself with the first reboot and sometimes it takes 3-4... Just flashed the stock 2.3.7 to get Wallet and then matrix and that's when it started happening.
  11. #11
    actionjackson22's Avatar
    Posts
    Global Posts
    115 Global Posts
    ROM
    Gpa18/Matrix8.0
    try mounting it through clockwork then while your phone is plougged in and its in mount mode, unlplug and replug it. make sure u select mount usb storage
  12. #12
    I recently went back to stock 2.3.7 and this is happening to me occasionally.
    Most of the time, as previously stated, rebooting into recovery and mounting the sd card fixes it.
    This seems to happen most of the time if I've just come of out CWR for something, like a backup or re-flashing a kernel. But I don't reboot very often unless I'm going into CWR so that could just be a coincidence. I suppose it could be something with CWR and 2.3.7 but I'm not smart enough to know that for sure.
    I've only tried Peter's Stock GWK74 Odexed version in ROM Manager but w/ and w/o Matrix both had issues.
    This morning I tried a complete wipe, installed Peter's GWK74 Odexed and had the issue before I put a kernel on, so I don't think it's Matrix.
    my two cents.
    Nexus 4 / Stock | Nexus 7 / Stock | TFPrime / Hairy Bean 2.1.1
    @digitalslacker
    +digitalslacker
  13. #13
    So how do I reset everything if I can't download anything to my sd card because its unmounted?
  14. Thread Author  Thread Author    #14
    Just boot into recovery and mount sd card then reboot phone
  15. #15
    btw, I'm running stock deodexed 2.3.7 with the BFS netarchy kernel. I'm not sure what's wrong but my SD card refuses to mount despite a number of reboots and when I go into CWM I click mount the sdcard but it doesn't do anything when I reboot... still says sdcard isnt mounted.
  16. Thread Author  Thread Author    #16
    I also have this problem running the same set up.When it refuses to mount I boot into recovery mount the sd card and reboot and all is well
  17. #17
    Was able to get the phone to reset by rebooting and taking the battery out. SD card mounted and I flashed over to the CFS netarchy kernel and now it seems to be running fine.
  18. #18
    Paul627g's Avatar
    Posts
    Global Posts
    14,045 Global Posts
    ROM
    Milestone 1/Lean Kernel
    Yes I would stay away from the BFS versions of kernels... They are betas, works in progress and can be buggy.... I always go right to the CFS and everything is good to go.
  19. #19
    mhpspeed's Avatar
    Posts
    Global Posts
    55 Global Posts
    ROM
    STOCK
    I was having same problem with peter's 2.3.7 odexed and matrix. powering down and a battery pull usually did it. Sometimes mounting and unmonting through CWR would work but not always.
    Was getting tired of the problem and not being able to use my camera so I restored back to deck's rom and will just flash google wallet on that.
