Beezy,
I like the updates to the OP, that big red box sure catches the attention. Some extra punctuation will make it easier to read too... It's hard enough to get people to read stuff. They probably won't be willing to decipher it as well.
Here's all I've got so far, add it to the OP if you'd like!
FAQ:
Q: Should the menu button work while on the home screen?
A: No. It doesn’t work at this time. It should still work within apps.
Q: Can I change themes? Kernels? I need Voodoo! BLN! CANDY!!
A: Chill. This is an SDK port that is in the early stages of development – it’s not even really supposed to work. Feel free to play with flashing these things, but nobody has had success with it yet, and don’t report any issues.
Q: Continuous sync symbol?
A: It’s an issue with one of your google apps. Make sure none are trying to update. Make sure you don’t have any incompatible apps installed.
Q: NFC?
A: No. An emulator doesn’t have NFC, neither does this rom, for now.
